Old 02-21-2006
goodbyebluesky goodbyebluesky is offline
Senior Member
goodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond reputegoodbyebluesky has a reputation beyond repute
fiberglass from home depot...
I stopped by Home Depot today thinking I was going to ask them about ordering some mineral wool, or 703 fiberglass to save on shipping charges.
I ended up looking around and saw the fiberglass insulation they carry, and while most of it was much too thick to use to make panels (6" or thicker) they had some that was 3.5" thick, in a big roll for under 12 bucks. It came out to $0.29/sq ft!!
How can I tell how this stuff would compare with 703 or mineral wool? I'm tempted to give this stuff a try since price is seriously the biggest factor in my home studio, because it has to be.
Ibanez Ghostrider loaded with Gibson P.A.F.s
Epiphone Valve Special
1970s Martin Sigma DM-5
I sold all my recording gear so what am I still doing here?!
Old 02-21-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
It's not the same thing at all I don't think.
The fact that no one understands you doesn't mean you're an artist...
Old 02-21-2006
Senior Member
Well, can anyone elaborate? Either way, I think almost any type of fiberglass would absorb as well as foam. And at this point, buying mineral wool or 703 and having it shipped is just not an option.
Old 02-21-2006
Flypaper for freaks
There are a lot of threads in this forum that alreaedy elaborate far better than I could.
Old 02-21-2006
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
Yes, definitely do a search on mineral wool or rigid fiberglass.
I think I remember someone (someone knowledgable about this) saying that If you stack enough of the fluffy stuff (f/g) it is of some benefit.
Old 02-24-2006
myfipie myfipie is offline
Junior Member
myfipie is on a distinguished road
Here is a cool little trick.. Buy the fluffy fiber glass in the rolls and stack it from floor to ceiling in corners (leave in plastic).. You can then build a false fabric wall in front of that...
Glenn
GIK Acoustics
www.gikacoustics.com
Old 02-24-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
It is nowhere near as dense, so it won't stop bass frequencies as well as rigid fiberglass. Leaving it in the roll does work better as it remains compressed.
Old 02-24-2006
Diffusion Diffusion is offline
Future Astrophysicist
Diffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond repute
If you keep the fiberglass in rolls it can be an effective bass absorber, but the plastic wrap will prevent it from absorbing highs... if you decide to somehow hang the fiberglass from your walls the fiberglass will absorb highs, but it must be very thick in order to be effective... I'm talking up to 16 inches thick... so, when you improvise it can be effective, but not practical... I suggest searching a little harder for some 703...
Old 02-24-2006
check this out:
http://bobgolds.com/Absorber/home.htm
also, these are the NRC ratings of the home depot (Owens Corning fluffy pink) fiberglass (unfaced, 12 inches thick):
125hz 250hz 500hz 1000hz 2000hz 4000hz
1.14...1.09...1.09....0.99....1.00.....1.21
Old 02-24-2006
Jack Russell's Avatar
Jack Russell Jack Russell is offline
I smell home cookin!
Jack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond reputeJack Russell has a reputation beyond repute
I know where you are coming from regarding cost. I used standard 3.5-in R-13 and 9-in R-30 insulation on the walls and ceiling, respectively, of my studio. I know it isn't the best, but it is better than nothing.
Speaking of Home Depot, they also sell a product called CertainSound insulation. This appears to be denser, but the cost isn't much more. I went with that around my isolation booth.
Purists will probably scream at me for cutting corners, but you have to do what you have to do. I am lucky though: my studio is in a house in a rural area away from other houses. Thus, I'm not concerned so much about noise getting out of the structure.
You can also try doubling your drywall.
Hear Jack's music
See Jack's art
Hear Jack fart
Old 02-24-2006
2lim 2lim is offline
Dedicated Member
2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute2lim has a reputation beyond repute
Ask at Home Depot for Roxul Drainboard, or Roxul Safe N Sound. Awesome stuff, barely more expensive than the pink garbage.
Simon
  #12
Old 02-24-2006
Simon
I'm almost positive that won't be available to him... 99.9% sure. He's from Florida, and the Roxul products are usually only available up north... apparently, due to shipping costs from Canada to the southern US, Roxul was loosing more money than they were gaining it...
  #13
Old 02-25-2006
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
On a roll? 3.5"? What was it called? I'm getting stuff like that for my studio. It's called bonded logic, ultratouch. It is made from recycled jeans so wont damage health and wont make you all itchy. It has abosorbtion coefficients as good if not better than many of the 4" and 6" rigid fiberglass'. This is the spec sheet for it. Look at Acoustical performance, at 3.5".
  #14
Old 02-25-2006
I read about that stuff before... it's great stuff, and cheap as hell. Like you said it wont make you itchy and there are no dangerous particles you have to worry about breathing in, and it's NRC ratings are amazing... I tried looking for some myself a while ago but it wasnt for sale yet... let me know if you find some....
  #15
Old 02-26-2006
pandamonk's Avatar
I found a company here in the UK that sells it, but it's pretty expensive. Moreso than Rockwool, Knauf, etc. But it'll be worth the extra £££ for my mum not to worry about me breathing dangerous particles etc. I was wanting to cover my whole control room in the stuff, but it's too expensive so I'm just gonna cover the back wall, reflection points, and behind the speakers. Where are the best places to cover in a "live" room? Obviously bass traps, but where else? The rooms are tiny, like 6 1/2' x 7 1/2' for control room and live room 1, vocal booth is like 2' x 9', lol, and drum booth is 6' x 9'. I know it's tiny, but that's all i got to work with.
THE DAVEMANIA COLLECTION Glorifies HOME RECORDING and GUITAR/BASS MUSIC! A Reel Person Guitars and Basses 5 12-15-2001 14:56
THE DAVEMANIA COLLECTION Glorifies HOME RECORDING! A Reel Person Newbies 1 12-15-2001 01:41
THE DAVEMANIA COLLECTION Glorifies FREE HOME RECORDING CDS! A Reel Person Free Ads for Music / Recording Equipment 0 07-23-2001 03:07
THE DAVEMANIA COLLECTION Glorifies HOME RECORDING TECHNIQUES! A Reel Person Recording Techniques 0 07-23-2001 03:05
