Old 02-21-2006
caiomhian caiomhian is offline
Newbie
caiomhian is infamous around these partscaiomhian is infamous around these parts
Arrow Jazz Tone
I´m Recording A Jazzy Sounding Track At The Moment.
I´ve Got A Fender Blues Deluxe Tube Amp.
And A Thine Line Tele.
What Would Be Your Settings To Get The Best Sort Of Tone.
I´tried Using Various Effect´s.
But I Think Just Going Straight In With The Tone Rolled Back A Little On The Bridge Pickup Is The Best Tone I Can Get So Far.
Any Other Ideas Or Sugestion´s
Old 02-21-2006
fazil fazil is offline
Senior Member
fazil will become famous soon enough
try the neck pickup, it might sound a lot fuller.
The only "effect" I would use would be an eq.
Also, clean solid state amps often work really well for jazzy guitar sounds. Like the polytone.
What mic are you using ?
-Arno
Vocals are wasted time between solo's
Old 02-21-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Clean, clean, clean. The neck pickup is generally more mellow and "round" sounding. Don't be afraid to record direct through a good DI/Preamp for a clean jazz tone. It can be the perfect time to DI a guitar.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 02-21-2006
Newbie
Talking
ive got a couple of sm 58´s
there pritty good for what they are.
cheers for the advice.
im also using a wah on one of my tracks its an absalute bastard to eq.
Old 02-21-2006
Irish_Scorpion Irish_Scorpion is offline
Newbie
Irish_Scorpion is on a distinguished road
:\, whenever i want a jazzy sound, i tend to turn the treble down a little, scoop a decent amount of mids, and have the bass about as high, or higher than the treble.
Oh and neck pickup all the way *thumbs*
Old 02-21-2006
overrated overrated is offline
Newbie
overrated is on a distinguished road
I would place an SM58 at a 45 degree angle against the speaker cab facing the loudest speaker (assuming you have more than one speaker, the one with the most hiss) and run the other pointing directly at the same speaker about 2 - 3 inches away from the cabinet. If the amp is clean, and smooth you'll get a nice warm tone, and I would use the neck pick up for this. Its fuller, warmer, and adds a nice subtle tone for jazz stuff. To get a fuller sound on the track you could run a direct line in and double the guitar tracks.
i hope this helps, and this is all under the assumption that the amp you're using has a speaker cabinet or is a combo, not just head.
Satriani or Via? Molly Guitars and Basses 68 11-24-2007 09:43
Using a POD for bass tone Pastorob Guitars and Basses 2 06-04-2002 11:22
What does good tone mean to you? Blue Bear Sound Guitars and Basses 50 08-12-2001 18:41
String Sizes For Improved Tone mikeh Guitars and Basses 13 08-02-2001 14:53
