Studio Construction Pics
Seven months after moving, I've finally gotten to some real studio construction. Here are some rack construction pics. I built my rack into an existing built-in bookshelf/entertainment center/wet bar
Pic #1: shelf above space for TV removed |
Pic #2: new divider & shelf added
Pic #3: rack rails in
Pic #4: rack gear installed. It's still only about 1/2 wired, but this gets me 2 mic inputs and 2.1 monitoring (sitting on the countertop
)It still needs filling, finished, and a glass door salvaged from an old home stereo tower case cut to size and installed. I'll try to get the glass door in this week Stage 2, I'm gonna build a few framed wall-mount absorbers, and stuff some 4" rigid fiberglass over the bookshelves for some temporary treatment. Stage 3 construction involves tearing the drywall off the ceiling & walls, installing mic cable in the walls, mounting newly built monitors in the walls, rebuilding soundproof walls & ceiling, building a floating cloud, and adding 5.1 surround A little bit harder, I think ![]() |
Very nice!
Books, how do they affect acoustics?
IF... The Website |
Books are actually reall good for acoustics. They act as really good diffusors because each one in a shelf tends to be a different height, depth, and thickness. Book shelves are actually recommended for that quite often if you've got no other means to diffuse sound.
The number 1 cause of death in games is panic. http://webpages.charter.net/sonicclang/small.jpg www.myspace.com/sonicclangmusic Please check out my studio construction videos on youtube!!! Click here |
Cool pics man....
I'd show my "Studio", but none of y'all could handle it. You'd cream your shorts with jealousy....
I won the internets...... |
I'm sensing sarcasm...
Hey nice handy work there MS.
T |
![]() Nice rack MS.............
WARNING: THIS POST DOESN'T CONTAIN ANYTHING HELPFUL http://www.myspace.com/veritasrs __________________________________________________________________________________________________ Last edited by dragon: at 04:10 |
#12
#13
LOL............... ![]()
"Gorty's Tunes" |
#14
#15
Mike |
#16
I'm still only halfway through Stage 3, specifically the part about tearing off the drywall
#17
Awesome rack. Make sure to not totally remove the "wet bar" portion of it. Books, shmooks, you just need some nice, round reflective bottles and you're set.
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit |
#18
#19
Dude, that's freaking awesome. I'm building a rack, but it's a wee bit smaller. I'm getting the pieces cut tomorrow (I got the wood and put down all the lines for it) and I'll screw it together next friday. I'll put some pictures up then. ![]() |
#20
ahahahaha... |
#21
OK, after a few more months, it's time for an update. I finally brought in the pros, Sam Moore and his crew from Soundside Construction of Manteo, NC, and they have totally been kicking ass. In addition to the studio, they are expanding two bedrooms and adding a bath, and various sundry other projects. After three weeks, we are about a week from closein inspection on all of it.
First pic is the front wall. All the drywall in the studio was torn off, except behind the wet bar (not in this picture) and the left wall. I am dealing with decoupling those walls from the other side, due to shear wall construction here in hurricaneland. Also it would have been traumatic and expensive to demolish & rebuild the wet bar/rack OK, so you can see the slanty walls with boxes to soffit mount the mains, also a little slanted soffit to hide audio wiring (some of which you can see) and hold the center channel over the window. The window has had the factory storm window added and caulked tight. |
#22
By the way, those cans will be removed and all lighting will be surface mount, or mounted in a floating cloud yet to come. I'm trying to seal up that ceiling good, all walls (except mentioned above) will be finished with 2 layers of drywall hung on RC.
Here's the back wall, with the rack shown in the earlier pics. They have built some more slanty soffits, mainly to aim the rear surrounds at my head. The door will be replaced with a solid-core unit. This corner worries me most, because the heat pump compressors are right outside that door Further work on the exterior wall may be required I'm very pleased with the monitoring layout, I'll end up with all monitors at the specified angle for surround, and within 6" of equidistant from the mix position. We had a fun morning last week where I broke out a calc and applied some trig so the angles were good. Then when they were done, we dropped lines back to the mix position, they were worried when it was like 1" off, but I was like, dudes, my head is 12", don't sweat it! Real carpenters are amazing Tomorrow the HVAC guys come to quiet down the furnace in the room, and baffle the intake. Also I get a humidifier! ![]() |
#23
Awesome, Jon. So is that the same room where my MSH mics were made? ![]()
#24
Here is where they are assembled: http://www.homerecording.com/bbs/att...chmentid=28007 |
#25
| How to Run a Studio | frederic | Studio Building & Display | 66 | 04-12-2009 13:06 |
| Building Studio In Pole Barn – Need Construction Advice | MoBettaBlues | Studio Building & Display | 26 | 07-12-2008 09:22 |
| RC in a home studio - construction question | adam | Studio Building & Display | 9 | 04-01-2004 12:14 |
| Small Studio Construction - Need a few opions | ENIGMACODE | Studio Building & Display | 7 | 10-30-2003 15:45 |
| Small Studio Construction - How bout a little help? | ENIGMACODE | Studio Building & Display | 0 | 10-29-2003 20:39 |
