Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 02-20-2006
dmbfan1981 dmbfan1981 is offline
Senior Member
dmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond reputedmbfan1981 has a reputation beyond repute
Question Please Help!!!
i have been trying to play midi through cakewalk sonar producer and i get this wierd warbly effect..almost like a tremelo effect.
I am using an m-audio 49 and when i first started using it i had no problems. If i play the keyboard through the music teacher software that came with it, it plays fine, which makes me think that it must be something in Sonar, but i do not know how to adjust it. I am running it through the cakewalk tss-1 softsynth which sounds good other than that annoying problem. PLEASE HELP!!!!
Dell 1505 laptop
Furman M-8
Behringer Balanced Patchbay
Behringer V-amp Pro
M-audio FW410
DMP3
MXL 990
Audio Technica 3035
KRK rp8
Old 02-20-2006
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
Please, post such questions in one place, thus minimizing the chance of two or more people wasting their time answering a question that they can't know has been answered already in another thread...
One possible source of this effect you describe (if I'm interpeting your description correctly) is if you have recorded the MIDI tracks to audio, and then play back the audio rendering and the original MIDI tracks together. Then your audio card is passing two nearly identical audio signals at the same time, causing comb filtering, which can just make the tracks sound washed out and nasal, or cause a beating effect if more extreme... So if this is the case, either mute the MIDI tracks or mute the audio tracks with the MIDI in them.
Even if you didn't mean this to happen, it's possible it happened to you inadvertently by thinking that you were recording audio along with the MIDI tracks, but routing in such a way that the MIDI sounds are also recorded onto your audio track with whatever you're playing or singing. To test this, mute everything except one audio track and play it back. Is there only one thing there, or are the MIDI tracks audible too?
If you recorded multiple tracks this way the problem would get worse and worse the more tracks you record, as more copies of the same audio, all very slightly different, interfere with each other.
Old 02-20-2006
altitude909's Avatar
altitude909 altitude909 is online now
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Check your modulation wheel
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
