What do I need to set up Mp3 files from my MD8? Also, the 2 aux sends on the MD8 are limiting so I was thinking about getting a Mackie or something that has 6 aux sends. I'm also thinking about trashing everything and going Pro Tools/Mackie/Hard drive. What do you think?
woah buddy...
Decide what you want before you go any further...
But if you do decide to stick with the MD8, here's how I get the shiznit on my computer. MD8 --> Standalone CD burner burned CD --> my computer (via audiograbber) wav file --> soundforge (for mastering) wav file --> cakewalk (for mixing if neccesary) wav file --> back into soundforge for more mastering wav file --> mp3 encoder mp3 file --> to the masses does that make sense? I'll go into more detail if needs be. -nilbog |
What about. . .
This may be obvious but what about going into a CDRW on the computer?
I ask because I'm looking to buy one (an HP I think) and I'm hoping to use this as part of my studio. Is there any major difference in features or sound quality between a standalone and a computer based CD burner? Thanks. |
Well to get the audio onto your computer's cd burner, your going to have to record it through your soundcard. That's the reason for having the standalone burner - you bypass the soundcard altogether. This is a good thing, because most consumer grade soundcards are going to be bad for your sound.
I have both a standalone, and a computer burner, and when I have my final wav I can either burn it back to a cd, or convert it to an mp3. hope that helps. -nilbog |
Yes it does, thanks. I had a feeling that cramming your track through that little 1/8" connector probably wasn't a good thing.
If I could pester you a bit more, what about a Turtle Beach card or some kind of breakout box/AD/DA converter to get into the computer with? BTW, is your name intentionally 'Goblin' spelled backwards? |
Well, some people will tell you that one of those nice pro soundcards will work fine, but I'm like you, it just don't feel right going through that little cable.
A decent soundcard and a cd burner will cost about the same, but if you go with the standalone burner, you HAVE a standalone burner for other things. So yeah, I tend to have a little more faith with the burner. -nilbog p.s. Much speculation around my name, I can neither confirm not den anything. |
