?Instrument level signal?
From one end of the internet to the other I've been trying to answer this;
What is "instrument level signal"? What is supposed to go into the front of a guitar amp? Actually what I'm wanting to do, is run from my mackie 808m, back into a guitar amp, but I can't find any specs on what the input of the guitar amp should be... ![]() |
Just keep everything low..... ![]()
I won the internets...... |
It's basically the "consumer" line level, -10dBV which is around 0.3V. Most passive instruments can generate about that level, a little higher if you whack 'em good.
Hey dogman, I was using that digitech pedal you gave me (the yellow one
) as a splitter between Sans GT2 to mackie PA, and the boss metalzone pedal to the crap...I mean crate. I noticed a huge improvement when I ran guitar straight to GT2 and then to the mackie PA.I was just wanking around with the idea of eliminating the accursed metalzone by going sans GT2-mackie-crate... somehow. This is what happens when you don't have a real amp. Quote:
http://www.mackie.com/pdf/ppm808m_ss.pdf +4dBu (1.3V) nominal, +20dBu (8V) max. Probably a little hot for a guitar amp, so if you get distortion, turn it down a bit. Do NOT connect the power amp outs to the guitar amp ![]() |
Thanks mshilarious! |
Am I being lulled into a false sense of safety and security then?
In which case I should definitely connect from the power amp...right? |
It works better if you have an FX loop on your guitar amp. You run the Sansamp into a mixer channel run, the monitor out to the guitar amp FX return, and use the mixer's Aux Send knob as a volume control. That way you don't overdrive the guitar amp's input. I used to run this way at small gigs with my Digitech 2120 Preamp. It allowed me to have a really low stage volume and a nice beefy tone through the P.A.
#12
Thanks ocnor, I'll try that. |
| DITHERING...A few questions... | RAMI | Mixing / Mastering | 32 | 11-07-2005 11:30 |
| Calibrating a Tascam 22-2 | citizenkeith | Analog Only | 7 | 09-20-2005 16:17 |
| question about DI | FALKEN | Recording Techniques | 24 | 09-16-2005 22:52 |
| On expanding dynamic range | StylusEpix | Recording Techniques | 14 | 01-11-2005 14:49 |
| which volume level in my signal chain can i cut to stamp out distortion? | jugalo180 | Mixing / Mastering | 5 | 10-28-2002 16:14 |
