Multi-effect/mic/single effect on 2488
Hey ya'll, how is everyone? I have a question...as you know i just got my 2488, had it about a week now. Gotten excellent results tracking with one exception: when I record, I am going with rhythm guitar #1 to track 2 and rhythm guitar #2 to track 3. Instead of micing one of my cabs, I am using Input G as it is the "instrument pre" input, right? So, when I have recorded either Rhythm guitar using the on-board multi-effect, it sounds pretty good (for DI). Then after I save it, and go back to listen to it again to add more tracks, etc. the effects that I recorded onto track 2 and track 3 are not there anymore. It happens when I reload the song and when I just save and then go to playback. Then, when I try to add them again, the multi-effect button (MIC x 4 or MIC x 8) will only let me add it to one track, never both simultaneously. But even if I assign the multi-effect to one specific track, say track 2, then save it, it is gone again when I playback/reload the song.
What do I need to do? Is this a "I don't know what I'm doing problem" or what? AM I not saving the tracks right? Do I need to record guitars dry then add effects after? Am I missing something in the effect assignment section of the manual? All comments readily accepted!!!! Please ask for more info if you need it...I just want to get over this hump and on to the next hump on my learning curve from the 424 MKIII to the 2488! Thanks everyone!
Matt Asbury Kernersville, NC 27284 |
Bounce
if it's not happening in the room, it ain't gonna happen on tape.-HG |
To add a bit of clarity, I hope, to the 2488 effects situation:
The MULTI effect can only be enabled on one track at a time. If you want the same (or different) MULTI setting applied to more than one track, you have to bounce each track + Multi to another track, then repeat as necessary for each track to which you wish to have the Multi effect applied, as COOLCAT states above. MULTI is an effect chain that includes a noise gate, amp model, modulation effect, distortion OR compressor, and delay. Each one of the effects can be edited, and switched into or out of the effects chain. The MIC X 4 effect is a single effect (choose between either a compressor, de-esser, or vocal exciter) that can be applied to up to 4 tracks simultaneously. When MIC X 4 is enabled, one additional track - not one of the 4 using MIC X 4 - can have the MULTI effect enabled, as well. The MULTI effect can be used independently of the MIC X 4 effect. The MIC X 8 effect offers the same effect options as MIC X 4, and can be applied to up to 8 tracks simultaneously. If MIC X 8 is enabled, the MULTI effect is disabled for all tracks. Not to forget the SINGLE effect, with which one effect from a library of presets (or user-defined settings) can be applied to all 24 tracks, with the send level for each track defined by the SEND function. The SINGLE effect can be used in addition to the [MULTI and MIC X 4] or [MIC X 8 effects]. So the maximum number of effects that can be used at any one time is as follows: SINGLE (24 tracks) + MULTI (1 track) + MIC X 4 (4 tracks, mutually exclusive from the track using MULTI) OR: SINGLE (24 tracks) + MIC X 8 (8 tracks) Oh, and let's not forget that each track has two external effects loops, so if you had 48 effects engines, you could have all that running in addition to the above. Hope this helps! |
| Just bought a new TASCAM 2488 | mandpasbury | TASCAM User Forum | 10 | 02-10-2006 14:09 |
| TASCAM 2488 and MIDI | Zaphod B | TASCAM User Forum | 14 | 12-08-2005 11:36 |
| for sale: lexicon alex multi effect unit | maskedman72 | Free Ads for Music / Recording Equipment | 1 | 04-13-2004 18:51 |
| Looking for good distortion/overdrive effect. | musicmaker | Guitars and Basses | 11 | 09-29-2000 10:04 |
| effects loop w/ p.s. 246 | monk | TASCAM User Forum | 3 | 02-23-2000 11:14 |
