Old 02-17-2006
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
Rigid Fiberglass or Rockwool
Or both? Which is typically cheaper? I guess you could build a broadband absorber with some rockwool in the corner and then put a panel of OC 703 in front of it...?
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 02-17-2006
bpape's Avatar
bpape bpape is offline
Acoustic Designer - GIK
bpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond reputebpape has a reputation beyond repute
In some areas of the country, rockwool/mineral wool is cheaper than rigid fiberglass.
For broadband absorbers, either will work. 6" of 3lb fiberglass 4" of 6lb fiberglass, or 4" of 8lb mineral wool straddling the corner will all do a good job.
For reflection panels, I wouldn't go any more than the 6lb or you run the risk of 'grazing' high frequencies at high angles of incidence. If you're going to DIY them, then 3lb (703 or equivalent) fiberglass or 4.5lb mineral wool is cheaper and will do just as good a job.
Bryan
I am serious... and don't call me Shirley
GIK Acoustics
Old 02-18-2006
Tonio Tonio is offline
Force of Nature
Tonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond reputeTonio has a reputation beyond repute
Hey bpape whats the density of rock wool is @ sss? My supplier of oc is out of stock, even their LA warehouse
PM if this is inappropriate.
>> never mind, 8lbs
Old 02-19-2006
bpape's Avatar
8lb is all I stock as it's what's mostly asked for. I can get less dense for refleciton points if you want but it's special order.
GIK Acoustics
Old 02-19-2006
Innovations's Avatar
Innovations Innovations is offline
1K Silver Member
Innovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond reputeInnovations has a reputation beyond repute
Rock wool is a byproduct of smeting and fiberglass is a is a byproduct of glassmaking. Both are bulky to ship and thus cost less closer to whatever plant closer. Accousting properties for similar densities and coatings are essentially identical
*STICKY* Where to Buy Rigid Fiberglass reshp1 Studio Building & Display 110 09-17-2009 03:15
rigid fiberglass help please. vangore Studio Building & Display 3 12-15-2005 13:54
Buyers Guide to Rigid Fiberglass Scottgman Studio Building & Display 35 07-13-2005 12:09
Rigid fiberglass ??? gvarko Studio Building & Display 35 01-19-2005 16:19
i think i found some rigid fiberglass notbradsohner Studio Building & Display 2 03-23-2004 02:50
