Old 02-15-2006
pappy999 pappy999 is offline
Senior Member
pappy999 will become famous soon enoughpappy999 will become famous soon enough
Compression during drum tracking.....COMMON PRACTICE???
I was thinking about putting some compression on the snare and kick drum during my next tracking session to try to even out hits a little. Is this a common practice?
Old 02-16-2006
Fletcher's Avatar
Fletcher Fletcher is offline
Force of Nature
Fletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond reputeFletcher has a reputation beyond repute
Unfotunately it's a bit too common... and usually performed with crap compressors that are overused [which makes the product a real bitch to mix].
I would recommend that if you absolutely feel the need to compress the drums to do it at a point after the recording process when you can pay full attention to the compression [and it's actions/reactions to the material played].
When you're tracking you have many things on which you will need to concentrate. #1 is the feel of the performance... #2 is the texture of the performance and how it relates to the texture(s) of the song... #3 is the overall sound of the drums and #4 is if every hit is of quasi-equal volume. If you focus on "#4" during the recording you could miss some very important stuff as it relates to "#2" and "#3".
Two things you might want to think about that might change your perspective on recording in general... the first is that a recording studio is an instrument that takes years to learn to play [like any other instrument takes years to learn to play]; the second is that like any other instrument; once you know how to do something it doesn't mean you should necessarily do it. You know you're an engineer when you know what all the knobs do but can make really good product by touching as few of them as humanly possible.
Best of luck with it.
Fletcher
Mercenary Audio
mwagener wrote on Sat, 11 September 2004 14:33
We are selling emotions, there are no emotions in a grid
Old 02-16-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Nice
Pappy - Definetly experiment with compression, but it's really better to preserve the full dynamics during recording and then non-destructavely add compression during mixdown. By non-destructively I mean don't overwrite the original tracks. You might find a sound you like while tweaking the drums as a group or solo'd, and then find later it doesn't work in the mix.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 02-16-2006
Kronpox's Avatar
Kronpox Kronpox is offline
Junior Member
Kronpox is on a distinguished road
Unless you're able to record the drum tracks onto separate tracks for each part of the kit, then post-recording compression will not give you your desired effect, as it would compress the entire kit with the same settings. So if this is what you're stuck with, then compress during recording, but spend a while making sure it sounds good as a kit.
Old 02-16-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I used to use a little mild compression on the way in... But ever since 24-bit has become the standard, there really is no reason for it unless it's for a particular effect - And even then, I normally won't bother and just take care of it later.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-16-2006
PhiloBeddoe PhiloBeddoe is offline
Dedicated Member
PhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond reputePhiloBeddoe has a reputation beyond repute
I think a good rule of thumb is that if you're absolutely positive you have the sound you want using a compressor (or eq) while recording, then go ahead and do it. But - it requires a lot of experience to have that confidence. I prefer to add compression later.
Having badly set and/or cheap compression sounds can break your recording, so it's risky unless you know what you're doing.
Old 02-17-2006
dr.colossus's Avatar
dr.colossus dr.colossus is offline
Force of Nature
dr.colossus is a jewel in the roughdr.colossus is a jewel in the roughdr.colossus is a jewel in the rough
- In fact its probably better to add the drums after the recording as well. Try and record blank tracks with nothing on them, then you can cut and paste a sample where the missing drum tracks are, this way your sure to get the right sound!
Sorry, I'm not usually sarcastic, but I do think its a good idea to experiment on the way in. I'm nowhere near as experienced as Fletcher or Massive, but I think its nice to catch the sound to tape (HD/ADAT/whatever). Setting up the compression is as important a part of the sound as picking the right mic, the right pre and the right drum, and you can;t do any of those sfter you've recorded. I find that it helps my mixes to have most of the work done before i push the faders, and when your working with a limited amount of outboard gear it makes the luxury of series compression more available. My two cents
Old 02-17-2006
I see your point, but well-played drums rarely require much compression (if any at all)... Recording *through* a compressor and being stuck with it when you're not certain of how it'll eventually fit into the mix just seems...
I dunno... I'd rather take my chances by keeping those options open.
Old 02-17-2006
TuoKaerf's Avatar
TuoKaerf TuoKaerf is offline
Music To Punch Babies To
TuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant future
Ever think to try and get the drummer to play better versus using effects to fix what they are doing?
Digi Certified
http://www.protoolsforum.com/images/PTBanner.jpeg
Old 02-17-2006
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
it TOTALLY depends on the drummer. The drummer in one of my bands plays very consistently....in fact his kick drum needs no compression at all. the last time I recorded him I put a mic about 6' in front of the kit and compressed it just for effect....everything else dry. In my other band the drummer plays VERY dynamically....its amazing, he makes the kit sound more like an 'instrument' than anybody I've ever heard play. He can make it say anything. Unfortunately, to make it say "rock n roll" he gets 2:1 with 3-4 db gain reduction on the hard hits med attack med release on the kick and snare.
Old 02-17-2006
Scottgman's Avatar
Scottgman Scottgman is offline
Legend in Own Mind
Scottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond repute
So am I a total idiot for compressing on the way in? I'll compress the overheads and the kick/snare. I'm talking 6:1, fast attack, medium release, but I set the threshold so that it only compresses the wild hits.
My thinking is that I don't want to dick around with trying to "fix" a clipped snare hit in the overheads (or whatever) after the fact-- or have to re-track what was an otherwise stellar performance because of some distorted drum hits. So I guess I'm using the compressors more as a safety net than as an "effect."
I dunno, I use an RNLA on the overheads and RNCs on the snare/kick. I really like the way it sounds. Also, I'm always recording the same drummer in the same room on the same kit and using the same mics/pres and have been tracking this way for a while. So I'm pretty familiar with the equipment and the results I'm getting. The drummer and I have done alot of experimenting and dialed in this sound. I suppose I would approach it differently if I was recording a different drummer/kit every time.
But what the hell do I know? I'm just a novice.
Talk Nerdy To Me.
  #12
Old 02-17-2006
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
i don't do any thing on the way in...... cause i mean
why?
is there some reason you can't do it later?
it would make more sense if you had a limited amount of compressors and knew you would be using them for other things later.
but i mix in the box, so there's no danger of that.
(actually, i would do it on the 2-track live stuff that i occasionally do because i use a mini disc player to record that stuff, and would like to be able to hit it a little harder...... cause MD kinda bites)
audio?
seriously, give me negative rep.
  #13
Old 02-17-2006
giraffe's Avatar
i love negative rep
what's that quote bruce used to have in his sig?
i think it went
there is no prize for being as close to zero as possible. people will not like you better, and girls will not be more attracted to you.
something like that anyway......
audio?
  #14
Old 02-17-2006
Scottgman's Avatar
Legend in Own Mind
i think it went
Point taken. But I don't push the gain-- at least I don't think I do. I try to keep everything away from the red and I would say the average hit is around -12db. My overheads are probably even lower than that. However, sometimes a wild hit will clip and sound like ass and the overheads seem especially prone to this. But I'm talking 2 hits per song might clip. So I'd rather use compressors on the way in to avoid those two hits that will cause me an ulcer down the road.
Maybe I'm compensating for my poor engineering skills or maybe my drummer needs to work on his control, but it's been working for me and I like the results. Of course, I've never tracked in a really nice room with an array of APIs and Neves at my disposal. I'm using RNP and Toft level gear here. So, again... what do I know??
Talk Nerdy To Me.
  #15
Old 02-17-2006
giraffe's Avatar
i love negative rep
how low are your overs?
if they're close moving them up will help with this a little.
when i set my overs, i set them so they peak at about 3/4. YMMV
possibly it's your drummers fault though, not yours.
(dynamic issues)
p.s.
the best pre i own is a dmp3
and the most i've ever spent on a mic is 400$ for my nt2a (although i have a re27, which sells new for more than that but i paid about 200$ for it)
so if it takes neves to know what you're doing, i'm in for a long haul.
audio?
  #16
Old 02-17-2006
giraffe's Avatar
i love negative rep
also, like i said it makes a little more sense with hardware because it frees them up to do other things later.
audio?
  #17
Old 02-17-2006
vintagetobes's Avatar
vintagetobes vintagetobes is offline
Senior Member
vintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to behold
would a limiter be a good idea on the way in? Im having trouble taming wild hits.
  #18
Old 02-17-2006
pointfive pointfive is offline
Junior Member
pointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant futurepointfive has a brilliant future
This is my band's situation, and we compress during recording (just the snare). Our music tends to span a pretty wide dynamic range, so for us to keep things even I find it necessary to compress. We have a good drummer now--very even--so this works well. When I was drumming (out of sheer necessity), I had to compress to handle the inconsistencies in my playing; not good.
I'm a self-taught amateur, though, so take everything I'm saying with a shaker of salt.
www.pointfive.com - divergent indie rock
  #19
Old 02-17-2006
Junior Member
This is another thing for us. We have only 1 RNC. I am going to purchase another when I can, but for now I tend to lightly compress a number of things during recording so I can free up the RNC for use during mixdown if need be.
  #20
Old 02-18-2006
Senior Member
I am recording a ton of different drummers and styles. I spend a lot of time on my mixes to get consistent kick and snare hits. I was thinking of using a compressor to save time in post production. If every drummer I recorded was perfect, consistency would not be an issue.
  #21
Old 02-18-2006
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
In Mix mag. I have read a ton of articles in the " classis tracks" or "producers/mix masters" catagorys. They all as I remember use compression going in. Some even talk about how they really "slam" the overheads or the bottom snare mic. I compress on the way in my kick and snare. Just to try to even them out. I'm talking very low ratio's. 1.5 0r 2:1. Does it help? I dunno? I guess the safe bet is NOT to but I figure if I am careful, listen real good while setting up, I can compress on the way in and have it be ok. This topic is very subjective.
People always seem to embrace the future then long for the past
  #22
Old 02-19-2006
twostone twostone is offline
Senior Member
twostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond reputetwostone has a reputation beyond repute
I like to compress all kind of instruments because of musicians lack of consistency not do I only appliy to drums but just about all of instruments from accustic guitars, drums for drummers who beat the fuck out of them, on vocals for those who scream their lyrics and I've lerned it's a great tool for auto leveling signals and that's my main reason I use before and after mix down I suggest go for it until you get the hang of it.
  #23
Old 02-19-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I'd say, in homerecording...whatever gets the desired result. I track all my vocals with an RNC. I can't sing. This just helps me in the long run. If something helps you get the results you want, do it.
I won the internets......
  #24
Old 02-28-2006
Reggie's Avatar
Reggie Reggie is offline
PutsTheLotionOnItsSkin
Reggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond repute
I'm not usually one to bring back a dead thread, but this one just tickled me. "Uh, hey guy. Could you, uh, like, play better? OK, thanks. Let's try another take...."
Noviss's (the producer) guide to compression. ethos DJ & Hip Hop Production 23 02-28-2006 06:04
Kick drum compression settings (W/DKFH) Tiger_ Recording Techniques 16 10-26-2005 09:03
Drum track compression affleckp Digital Recording & Computers 2 06-07-2005 08:16
Headphones for drum tracking... WATYF Other Equipment and Reviews 15 08-23-2004 11:54
Anyone have suggestions for drum practice? jake-owa Drums and Percussion 2 11-18-2002 18:53
