Making TSR-8's unbalanced connections balanced
Hi,
I want to take the 8 line outs from my TSR-8 into my Swissonic AD24 convertor (I know, how dare I) for the added tracks/flexibility in digital, however the TSR-8 has unbalanced rca outputs and my convertor only accepts balanced xlr ins. What are my options for making this conversion? |
yo,
check this out: http://www.jensentransformers.com/an/an003.pdf Either the "adaptor cable" solution or the diagram on the top of page 3 is probably your best bet. You might want to check with the Swissonic people so you don't damage anything. |
Great! So if I removed the jumpers then I would just need an eight channel unbalanced rca to XLR snake is that right? Thanks Zee..
... that's what in the manual. Page 10 has rca/xlr cable connecting/wiring diagrams... follow it, I guessalso, for general info you can take a look at this page |
Thanks for your help! I've got some reading to do, I've never made cables before, does anyone know where I can get some quality cable/connectors?
check this ...see there XLT-to-RCA (make sure you get the right male or female XLR connectors, I've seen them being confused all the time
![]() From what I read these cables look right for your situation. You need two wire shielded cable, XLR - Pin 2 - hot, then double check the manual description.... there are two 'configurations' there. As for where to buy parts in case you want to make cables... I buy parts always in local music store... just go to the "wall" where all the crap is hanging and get what I need ![]() On line? Most on-line music/gear stores have connectors and some cables usually available... it does not turn out much cheaper thouh comparing to buying pre-made cables if you buy on-line. Or maybe I don't know the 'right place' ???... As for parts quality - it depends who you ask. I've used Hosa cables with no problems and I've made many cables of mostly ProCo parts .... I don't know, it all worked for me just fine. hosa cables here - nobody beats HOSA ...LOL ProCo bulk Parts here - this is the brand I usually buy at local mus.store when making some cables etc... works good for me |
Would this work for me Zee? http://www.macmidimusic.com/prod.itml/icOid/8805 How do I know how it's connections are configured?
How do you know?
... by trying to find tech info ... which I've tried and and could not find any clear 'description' about it. If there's a chance to actually call the store where you buying from and try to get somebody who knows products, then you can get details...some packages have connection/wireing chart ... some don't ...The good thing about that snake, it looks like it made of these parts: RCA and XLR ... which means that you can modify connections if needed after you test it and figure out how it is originally configured. |
I think I'll try and contact Hosa in an e-mail and include the PDF as an attachment. Its worth a try!
I went to http://www.crownmagnetics.com/Home.htm to get special snakes made and they did a really good job.
#12
How much did it set you back reel?
#13
2 snakes - 15 ft. 8-channels each.
XLR female to TRS TRS to XLR male They customized the XLR ends, reversing the hot and cold pins to work with a 1985 Otari. It was between $200-250. |
| Why does a TRS cable minimize noise? | lirvala | Newbies | 20 | 08-02-2004 22:00 |
| Is there such a thing as a custom cable that connects balanced and unbalanced gear? | Chris F | Other Equipment and Reviews | 10 | 03-08-2003 13:32 |
| Balanced Unbalanced? | Jeroleen | Other Equipment and Reviews | 4 | 01-12-2002 19:33 |
| balanced / unbalanced - what's the deal? | silverlode | Newbies | 3 | 01-10-2002 17:44 |
| Balanced + unbalanced signals +patch bay | thelonious | The Rack | 0 | 03-29-2000 17:36 |
