Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 02-15-2006
thegatekeeper thegatekeeper is offline
Senior Member
thegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond reputethegatekeeper has a reputation beyond repute
Sustain Pedal Problem
Hi guys, I recently posted in the cubase forum but I think I'm never going to get a response there. I have a problem with my midi. I'm using a keystation pro 88, going via usb to the computer using Nuendo as my daw. I'm using Ivory as my vst. When I play and do some tracking I have no problem at all. My problem is that whenver I export it to an audio track, I lose my sustain pedal effect. I'm routing my midi in to from my keyboard and out to ivory. I do have the audio but the sustain is lost. I have also removed any filtering and yet I have the same problem. Any ideas?
Old 02-15-2006
Tifstorey's Avatar
Tifstorey Tifstorey is offline
Guinea Pig
Tifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond repute
You need to have the automation clicked when exporting your song out of Cubase. Providing you did use automation to save your pedal..
http://img182.imageshack.us/img182/867/forfeitbx4.jpg
"The Irish gave the bagpipes to the Scotts as a joke, but the Scotts haven't seen the joke yet."
Oliver Herford.
Proud member of GFCG
Membership No:
000 018
Old 02-15-2006
Senior Member
Well since I'm fairly new to midi, and it sounded good when I played and recorded I figured shit, I think it's going to work. So I have to activate the pedal in the midi track, is that it?
Old 02-15-2006
Tifstorey's Avatar
Guinea Pig
The sustain pedal should automatically be recognised, but theres a process called 'Automation' which is basically a way of recording settings.. For example, if i wished to change the volume up and down and in various ways on a clip of audio, i would use automation to record on that track and save my settings on the volume control.. i hope im making sense because i'm pretty tired right now
So yeah, in Cubase there should be a way to turn Automation on, then on the channel your using click it to 'Automation write' or 'Automation record' then use your pedal along with the track. That should then save it to the chosen midi channel.
Then when your exporting the track, ensure that 'include automation' is ticked.
Hope that helps,
Good luck.
Oliver Herford.
Membership No:
000 018
Old 02-15-2006
Senior Member
I know what automation is but my question is why would I have to turn it on, if when I playback what I recorded the pedal is working. The only thing that happens is that when I bounce it to an audio track the sustain effect is gone. I'll try it as soon as I get home. Thanks
Old 02-16-2006
Senior Member
well I tried that and it didn't work
Yamaha S80 sustain pedal averagegirl Keyboards and Sound Modules 2 09-19-2005 00:31
Problem with sustain when recording keyboard writerscramp MIDI Mania 1 07-02-2005 09:53
problem with amp donkeystyle Guitars and Basses 8 04-08-2005 15:57
4sale-Boss Compression Sustainer pedal blackscot Free Ads for Music / Recording Equipment 4 02-17-2005 12:08
Pedal Power/Power Conditioning darknailblue Guitars and Basses 1 01-07-2005 15:20
