Old 02-13-2006
tikka308 tikka308 is offline
Junior Member
tikka308 is on a distinguished road
Cable management
Saw this thread - http://homerecording.com/bbs/showthr...ble+management - but the eBay links were (understandably) expired.
I'm looking for 1) recommendations for cable management and 2) some pictures of well-executed cable management. I'm particularly curious how people "keep" power cables away from audio cables or force them to intersect at a 90 degree angle...
Thanks!
Presonus Firebox, Summit Audio 2ba-221, MD421, SM57, iMac G5, Mackie HR824
Old 02-13-2006
frederic's Avatar
frederic frederic is offline
frederic.midimonkey.com
frederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond reputefrederic has a reputation beyond repute
Essentially I was recommending a bunch of different "data center" type products that do what you're looking for.
Hooks, wire ties, eye bolts, all sorts of things for the DIY'er works well as well.
Many places sell velcro wire ties which are reusable - while more expensive, you don't have to have wire cutters handy to add, remove or change wiring.
You could even drape cabling across cheap coat hooks across the back of your racks - a top row of hooks for audio, a bottom row for power, for example.
Old 02-13-2006
Junior Member
Anybody have any pictures (or links to pictures) with good examples? (once again, referring more to the layout than the actual products)
I only have an Imac, a few mic's, a pre, and a pair of monitors for now - but will be growing and I'd like to start off on the right foot...
Old 02-15-2006
SonicClang SonicClang is offline
Part 4720981 coming soon!
SonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond reputeSonicClang has a reputation beyond repute
Exactly what KIND of cable management are you talking about? There's cable storage, where all your spare cables are organized in some manor. And there's hard wired cable management, where all the wires behind patch bays and stuff are tied together to keep them from turning into a rat's nest.
Which one do you mean?
The number 1 cause of death in games is panic.
http://webpages.charter.net/sonicclang/small.jpg
www.myspace.com/sonicclangmusic
Please check out my studio construction videos on youtube!!! Click here
Old 02-15-2006
Junior Member
Hard-wired cable management. Namely keeping power cables & audio cables correctly sorted (and apparently >3' apart or crossing at 90 degree).
Thanks!
Old 02-15-2006
Keeping power and audio cables 3 feet apart? Is that even possible? I can see 3 inches... but yes, don't run them parallel ever.
Old 02-15-2006
Junior Member
Is there a good way of keeping them 90 degrees (or just not parallel)? I don't know about you, but if I didn't have them taped/fixed somehow, they would (and currently do!) move all over the place...
Old 02-15-2006
Part of my job (at work, not in the studio) is organizing wires. It's a very small part of my job... but still part of it. When i'm putting a wiring harness together with 50 wires or so, I use wire ties like these
You can pretty much do whatever you need to do if you tie the wires together. I actually worked at a place where that was literally all I did. I tied wires together all day with wire ties, making them as absolutely pretty as humanly possible.
Cable length pdadda Mixing / Mastering 8 11-07-2005 00:57
Canare (Lavacable) vs Cobalt XLR Mic Cable ? mrplow Microphones 0 08-14-2005 18:44
Cable Basics - a primer for newbies homerecor Newbies 1 03-04-2004 06:45
The best quality cable? Mongoo Other Equipment and Reviews 6 02-18-2004 08:53
