Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-12-2006
altiris's Avatar
altiris altiris is offline
Force of Nature
altiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond repute
96k is better than 44.1k sample rate. why?
Something told me that sample rate was not audible frequency. So I searched for this. I found this article http://www.saecollege.de/reference_m...ders.htm#sampl
If you scroll down to the sampling rate where the sine wave is on this site, it will explain what that 44.1k sample rate actually means. So higher sample rate is higher resolution not higher frequency that the human ear can hear. So that means that the higher you sample at the closer to analog you get. Which means that 96K is better than 44.1k.
In conclusion you should record at 44.1k because “my DAW cant handle too many tracks at 96k” and not because “the human ear cant hear frequencies that high anyway”.
It's half full when you fill it and half empty when you spill it.http://dl2.glitter-graphics.net/pub/...jtstrnnu1n.gif
Old 02-12-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
But 10kHz will have 4.41 samples taken of each of it's waveforms. Now look at the first waveform we drew. In that drawing we took 6 samples of the waveform and got an amplitude reading saying 0,2,2,0,2,2. imagine how inaccurate 4.41 samples are of a complex waveform. That is why digital high frequencies sound harsh!! The industry has constantly denied this factor and even gone to the extent of saying the hear can't distinguish between a square wave and a sine wave above 7kHz. Pigs Bum.
At a sampling rate of 96kHz you get 9.6 samples of a 10kHz wave and believe me, you can hear it.
In an article by Rupert Neve, I read recently, he said that we should aim for 24bit resolution and 192kHz sampling rate if we want to equal the quality of high quality analogue recording. We will get there. DVD is already up to 24 bit 96kHz sampling so we are on the way. But if your 16bit, 44.1kHz CD sounds bright, consider what makes it bright and you will see that it's a false bright created by the high frequencies sounding like square waves!!
The author of that article lacks a fundamental understanding of digital audio theory. You can't simply reject Nyquist by saying "Pig's Bum".
Let's hear his audio files that "prove" he can hear it. Do the test yourself. Generate a 10kHz sine wave at 96kHz. Convert to 44.1kHz *using a high quality sample rate converter*. Now convert back. Listen to the two samples in a blind test and try to distinguish them. Report back with your results.
Old 02-12-2006
altiris's Avatar
Force of Nature
This is my research phase. And I will do the actual testing myself. But I’m mostly referring to “highest audible frequency” that I hear people say about the sample rate. I mean why even be capable of recording at higher frequencies if the human ear cant hear above the 20k or so? So to me I don’t believe the frequency it refers to is the “highest audible frequency” when we say sample rate.I’m open to clarification on this.
Old 02-12-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
this has been discussed many times over on this site and millions of other forums. I suggest do a search to read everyone's opinion on this topic.
also, you're confused on what the "highest audible frequency" that can be recorded is. It's not the sample rate itself that denotes the highest frequency. In other words, 44.1kHz is not the highest frequency recorded using 44.1kHz sampling rate. The Nyuist theory tells us that HALF of the sampling rate is the highest frequency that can be captured. So it's actually 22.05kHZ.
To add to your research, find out what the highest reproducable frequency is on your typical microphone and/or speaker....and ponder that.
www.redlabaudio.com
Old 02-12-2006
Faithful Departed
The sample rate needs to be a little more than twice the highest audible frequency. I will be the first to admit 44.1 isn't perfect, because it cuts 20kHz a little too close, resulting in very slight attenuation of frequencies above 18.5kHz. But 48kHz is fine. And most playback systems (or listener's ears) cannot hear the difference anyway.
Where digital audio has run into trouble in the past has had more to do with quality of converters rather than a flaw in the underlying theory. Sadly, statements like those from that site just show that the author doesn't understand the theory.
Yes, it is true that a 10kHz waveform will be more crudely represented as a square wave at 44.1 than 96. But it doesn't matter, because those square waves are distortions that are occuring at frequencies above 1/2 the sample rate, which are then removed by the D/A converter's anti-imaging filter. So the reconstructured waveform is identical to its analog parent (assuming no limitations of hardware, etc.)
Here's an FFT graph of the exact test I described. The lower graph is the 96 to 44.1 to 96. Mind you it has been through TWO sample rate conversions. The top is the 96 kHz original.
So, if there is audible distortion, where it is?
As a note, if I showed you the same analysis at 18.5kHz (10kHz is really not that tough), you'd see exactly what I described: a slight attenuation, but no audible harmonic distortion. Unless you have a better SRC than I do
Old 02-12-2006
snow lizard's Avatar
snow lizard snow lizard is offline
Dedicated Slacker
snow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond reputesnow lizard has a reputation beyond repute
You might want to check out the Sampling Theory PDF at Dan Lavry's website.
sl
Old 02-12-2006
altiris's Avatar
Force of Nature
I’ve often wondered that. And I guess that’s why you would not hear the difference since the mic is limiting you to 20k on most mics Id even be able to afford. And your monitors and everything else that caps off under 44k.
Old 02-12-2006
altiris's Avatar
Force of Nature
sl
I will check that out
Old 02-13-2006
pingu's Avatar
pingu pingu is offline
Dedicated Member
pingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond reputepingu has a reputation beyond repute
Old 02-13-2006
crowning crowning is offline
Newbie
crowning is on a distinguished road
It's quite easy: you won't hear any difference.
If you hear any differences at all it's because the filters/DACs are not as good
in the 44.1 kHz case.
It's much easier/inexpensiv to build filters for 96kHz sample rates.
Tom
My music:
http://www.synthesizer-music.com
My photos:
http://www.tom-crowning.com
Old 02-14-2006
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Well not entirely identical.
Let's take a theoretical worse case. You are sampling at Nyquist (40Khz) a 20Khz sine wave and the samples occurs at a zero crossing (twice). In this scenario you would get no signal at all and is one of the reasons why you should always sample above Nyquist (to get at least a few valid samples occuring during the cycle)
While the frequencies above Nyquist are syphoned off, there is still the possibility of quantization error (error in amplitude) at higher frequencies. Filtering doesn't take care of this, it just removes alias freqs.
I do agree however that his "pigs bum" comment in regards to undersampling and square waves is "horse shit" for the reasons that you have described.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
  #12
Old 02-14-2006
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
If I had the processing power, DAC's weren't limited to 48Khz(I mix OTB) and to a lesser extent storage space I'd do 96khz, I don't know if its cuz plug-ins sound better or if 96Khz just sound better then 44.1, but it does... its not a "o shit 96 sounds much better" but things just seem smoother to me when I mix 44.1 ITB and 88.2/96 ITB
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
  #13
Old 02-14-2006
altiris's Avatar
Force of Nature
Now could all this have anything to do with a problem I came across once. I was recoding some songs from the outs of my keyboard and 44.1k. I sounds just fine. Then I tried at 48.8k I noticed that at 48.8k some parts sounded muted. Not the whole song. like there is a part with a cello duel. At 48.8lk the duet is missing. I would go back to 44.1 and it could be heard again. So some frequencies are affected by sample rate?
  #14
Old 02-14-2006
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
With or without phase shift? Ponder THAT!
  #15
Old 02-14-2006
with AND without phase shift!
www.redlabaudio.com
  #16
Old 02-14-2006
Not in your situation. Especially not with a synth. The highest note on the synth wouldn't even come close to the highest reproducable frequency at 48kHz sampling rate. The highest note on a typical piano is C8 which is 4,186Hz. No where near the Nyquist Frequency of 24kHz.
www.redlabaudio.com
  #17
Old 02-15-2006
Ford Van's Avatar
Banned
I think if you dig a little deeper, and talk to some "tech" people at some manufactures, you will find that most mics and speaker systems do indeed go beyond 20KHz! The specs above 20k are seldom shown, because usually they are not flat.
If things slow down, and I remember, I will find some stuff for you.
  #18
Old 02-15-2006
altiris's Avatar
Force of Nature
wow theres more to frequencies than I thought.
  #19
Old 02-15-2006
which is one of the things I ponder
although I figured they may have left it off more because they just wanted to show the range of the human ear and how the mic responds within that range.
www.redlabaudio.com
  #20
Old 02-15-2006
Reggie's Avatar
Reggie Reggie is offline
PutsTheLotionOnItsSkin
Reggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond reputeReggie has a reputation beyond repute
This is some of the stuff that I've never been able to quite get my head around. Say you have a source that contains some 20k information. But as with many natural sounds it isn't perfect sine waves. Would a 44.1k sample rate be unable to convey the little imperfections since it is only sampling enough times to basically encode some sort of 20kHz sound, thereby causing the AD or DA convertors to sort of guess what shape the wave really is?
Aaaaand my head exploded.
BTW: I would worry a lot more about using 96K myself if people in the mainstream could listen to 96k CDs in their stereos.
  #21
Old 02-15-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
I'm all for it, and that'll be the day I start tracking everything at 96K.
Regards,
RD
http://www.myspace.com/twentysevenmoons
  #22
Old 02-15-2006
you have to understand that 20kHz is very very high in the frequency spectrum of music. This is mainly just going to be upper harmonics of instruments and not the fundamental note. Again, not many instruments really play much higher than the C8 note on the piano (around 4000Hz). The upper harmonics of a fundamental note is what gives each instrument their own timbre. And there are nuances up there that strengthen the sound of the instrument.
The middle C on piano is where a lot of instruments reside, and this is around 261Hz. This frequency's 76th harmonic is where it nears 20,000. Not a huge deal if we are losing some of that. Now yes, around C8...the 5th harmonic is nearer to 20,000 and the instrument may start to sound different than when we listen to it in the room. But again, human hearing (perfect hearing) is between 20-20kHz...even though most people don't hear that high. This range is one of the reasons 44.1kHz was decided upon...and then we got a safety net of 48kHz to use as well if you so choose (most people do).
look into anti-aliasing to help with your converter question
www.redlabaudio.com
  #23
Old 02-15-2006
guitarfreak12's Avatar
guitarfreak12 guitarfreak12 is offline
Dedicated Member
guitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to beholdguitarfreak12 is a splendid one to behold
it looks like that guy has no idea what he's talking about, frequency is to sampling rate as apples are to CARS!!
Omit Peas From the Menu
you Pot Bellied, Crazy, Solid Gold Dancer
  #24
Old 02-15-2006
well, balancing sample rate and frequency IS important. It helps avoid aliasing.
www.redlabaudio.com
  #25
Old 02-16-2006
Dedicated Member
true, but I think that guy doesn't really understand what the relationship between them is.
Bit and sample rate? Wireneck Cool Edit Pro / Adobe Audition Forum 4 08-21-2005 04:22
bit vs sample rate ohthatguy Other Equipment and Reviews 1 08-09-2004 23:40
Trying to burn a song with a 48k Sample rate hegui Roland, Boss, VS Series Forum 4 06-12-2003 14:34
Audiophile codex sample rate Doug H Digital Recording & Computers 0 06-01-2003 07:45
Changing sample rate Lambo Cool Edit Pro / Adobe Audition Forum 2 03-25-2000 11:59
