Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-12-2006
mark4man's Avatar
mark4man mark4man is offline
MoonMix Studios
mark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond repute
ITB Bounce vs. Digital Xfer
Here's a question for all you "in-the-box" wizards...
For a 16-Bit SONAR project, w/ plug-ins applied...will a real-time digital transfer (S/P DIF or ADAT) to an external hard disc recorder be identical to bouncing the project to a .wav file...or will it sound like the parent project?
As everybody here (painfully) knows...my CD project was all tracked & mixed in SONAR2, but I now do all my mixdowns out of SONAR4 (to take advantage of the universal bus routing, trim control on the stereo bus, etc.)
But I really prefer the way the projects sound via real-time playback in SONAR2. They may not even sound "technically" better...but I've worked the v2 mix to where it sounds exactly the way I want...& that's the sound I want, period.
My alternatives then become outputting analog (which is what I'm hearing...the sound of my AI's D/As) to an external HD recorder (Masterlink, etc.) or a digital transfer, also in real-time.
Will S/P DIF or ADAT grab all the extra plug-in DSP ambience from SONAR's internal processing depth, or will the digital signal be truncated? What if I convert the project to 24-Bit before I transfer?
And...will the digital output sound the same as what I'm hearing in typical real-time playback? Im not sure it will, 'cause the AI will be taking the signal prior to the D/A & piping that out via one of the two digital formats, right?
Maybe I should just do a frigin' analog & be done with it...I don't know. This is frustrating as shit. I have a mix I'm satisified with in SONAR2 & no way of getting that sound to redbook. F it all.
mark4man
Old 02-12-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Seems kinda quixotic to me. If you transfer to analog then an HD recorder to burn, then listen to the playback, then you will have the sound of your Sonar 2 mix, plus your D/A, plus the sound of the HD's A/D, plus the sound of the CD player's D/A.
Lemme ask you this: why doesn't a CD burned from the Sonar 2 mix, played back through your converters sound the same? If it's 16/44.1 the whole way, there seems to be some issue there.
Harder to get that "mesh" in digital than analog? producerkid Other Equipment and Reviews 6 01-31-2005 20:26
Help in Purchasing Digital equipment Jaze7 Digital Recording & Computers 1 04-02-2003 22:21
Digital Drum Tracks dmemphis Digital Recording & Computers 2 01-28-2003 18:26
Digital Mixers vs. Analog Mixers... pisces7378 Digital Recording & Computers 6 03-23-2002 10:00
The new myth about digital . . . chessrock The Rack 51 03-05-2002 04:21
