Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 02-11-2006
panos panos is offline
Newbie
panos is on a distinguished road
record roland drums to PC throygh MIDI connectors
Helloz,
My case is probably very simple but i still need detailed instructions as i luck complete knowledge of sound recording.
I have Roland TD-6KV drum set and i recently bought a soundblaster X-Fi Platinum card. All i want to do is record in some way what i play to a midi file through MIDI connectors (available I/O slots exist in both card and drum sound module). So if anyone could describe me the whole procedure i need to follow in terms of connectivity, settings to drum module etc i would really appreciate it...
Bye for now...
Old 02-11-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
What software r u using? Should be real easy
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 02-12-2006
Newbie
Got the one that came with the card and i am using it in the audio creation mode. Do i need 2 MIDI cables i.e. MIDI IN drums ->MIDI OUT PC and vice versa or just connect the O/P from the drums to the PC? I just want to make sure that i got this step right because i am a bit confused...
Old 02-12-2006
You need to be more specifc than that. Midi is not audio so you need something that will record midi
To record the midi signal you just need the output from the drum machine. To play it back you will need the input on the drum machine connect also. If you want to record the audio, you will need the audio out connected
midimonkey wiring frederic Studio Building & Display 7 11-25-2005 21:33
Record midi track to audio track masantha Cubase User Forum 7 04-27-2005 14:51
Drum Machine Midi Question - Alesis DM-Pro ebitda Cubase User Forum 2 05-23-2004 17:43
Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! Rish Fostex Forum 0 12-12-2000 13:32
new studio need help.. fast!! Readytodothis Newbies 8 04-06-2000 01:55
