Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-09-2006
djclueveli djclueveli is offline
Dedicated Member
djclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond repute
gain S/N ratio
i don't have a good vocal booth to record so i just record in the closet. i heard that if you don't want the room to effect the vocals that much than you should turn the gain down real low. i turned down the gain pretty low but now my vocs are low and when i raise the output level it's just more noise now. But turnin the gain up will make the vocals sound kinda boxy because of the room i'm recording in. anybody have any solution to help me solve this problem?
Old 02-10-2006
fweyd fweyd is offline
Senior Member
fweyd is on a distinguished road
reverb ?
Waves' TruVerb works wonders
Old 02-10-2006
MikeA MikeA is offline
Dedicated Member
MikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond reputeMikeA has a reputation beyond repute
Don't take the coats out before you get in the closet. It'll be a liitle tight but 5 or 6 heavy coats should absorb a lot of the boxiness.
Old 02-10-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You got bad advise. The only way to keep the room out of your vocal is to sing louder and closer to the mic.
Even though a vocal booth seems like a closet, a well designed booth has a ton of acoustic treatment designed to not sound boxy. In your situation, you would be better off in the biggest room you have. Set up right in the middle of it. It is the reflections off the walls that are coloring your sound, in a closet, you have placed the walls even closer to your mic.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 02-10-2006
Dedicated Member
thanks for the advice you guys.
Old 02-10-2006
Dedicated Member
if i have to go closer to the mic, do i have to reduce the gain and output level so the mic won't clip and sound harsh on certain words?
Old 02-10-2006
Farview's Avatar
you turn down the preamp. You would be hard pressed to clip the mic, the preamp is what clips.
Jay Walsh
Old 02-10-2006
Dedicated Member
thanks alot!
Old 02-10-2006
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
But be aware of proximity effect, and how it changes the tone of the mic.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 02-10-2006
Farview's Avatar
You might need to get a pop screen. You will also have to roll off the low end to get it to sound like it did.
Jay Walsh
Old 02-10-2006
Dedicated Member
yea i have a pop filter. do u mean roll off low end on the mic while recording or when mixing?
  #12
Old 02-10-2006
Farview's Avatar
It doesn't matter when you roll it off. You don't have to, if you don't want to. The closer you get to the mic, the more low end you will have. If it's too much, roll it off.
Jay Walsh
  #13
Old 02-10-2006
Dedicated Member
ok i see now. thanks
Dynamic Mics and Gain, and more Gain Phinney Microphones 4 06-13-2005 15:50
MR-8 song perfect, but then too soft when moved to PC Mons Fostex Forum 16 02-03-2005 09:55
noob q: Gain Stages in my Preamp dirtythermos The Rack 0 01-21-2004 12:27
Preamp input gain problem? muser Microphones 3 02-01-2003 13:20
RNP ....release update? bostonfan2 The Rack 27 09-23-2002 15:16
