Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 02-09-2006
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
Rec/playback levels
Soundcraft 6000 desk > HD24
My Elco - 1/4" sends/returns (for the multitrack) were wired unbalanced when I bought the desk and have remained that way. The Elcos are 5m, I believe.
I was wondering if the fact that I'm using unbalanced connections may be the cause of a pretty big difference between monitoring levels when recording (through the desk's pres) and then playing back. It's a major pain, since whenever I record through the desk's mic pres, I have to reset the trims at playback.
Can anyone offer anything?
Seems pretty silly that trims should require constant adjusting all the time.
Old 02-09-2006
rossM rossM is offline
Newbie
rossM will become famous soon enough
I have a soundcraft console that I run unbalanced cables from to a Fostex 24 tr hdr - At a guess - this is not a balanced/ unbalanced isssue as much as a -10 db +4 db issue - I would suggest you have some mismatch between the levels in the desk and the HDr - -Soundcraft desks were usually set up for +4 db line level operation - (whether balanced or unballanced) but check the manual on your desk on the SOundcraft website .
Old 02-09-2006
Force of Nature
Hi, Ross, and thanks for posting.
The Master section does have -10/+4 switching (per channel), and I've tried both positions in the past, but it didn't alleviate the problem. In fact, it didn't appear to make any difference at all.
Something can't be right though, I'm sure.
Sounding good at the right levels sjoko2 Mixing / Mastering 29 02-03-2006 18:43
levels question hawk Newbies 11 12-22-2003 18:13
What is going on with my levels? coplinger Sony Tools / Sonic Foundry 5 09-20-2002 06:04
recording levels david j. cook Recording Techniques 0 10-10-2001 14:24
