Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 02-07-2006
Butch-1's Avatar
Butch-1 Butch-1 is offline
Newbie
Butch-1 is on a distinguished road
Question Recording on VS 1880
should I go stright from the Drums into the 1880 or
Drums to my mackie mixer then to the 1880..
My worry is if i go Stright to the 1880 will I have enough EQ for the Kick Drum and Bass Guitar..
The Tytus Hale Band
Old 02-09-2006
ermghoti ermghoti is offline
1K Silver Member
ermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond reputeermghoti has a reputation beyond repute
You can bounce all the tracks with eq patches after you record, most likely to vtracks. You will retain the unmolested tracks in case your eq tweaks don't work out later in the mix. You also have onboard eq for each track, without using an effect. No reason to eq on the way in, unless you know 100% from experience that a certain curve is absolutely always going to make the final cut.
Old 02-20-2006
GONZO-X's Avatar
GONZO-X GONZO-X is offline
1K Silver Member
GONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond reputeGONZO-X has a reputation beyond repute
the mixer, will provide a stronger/possibly better sounding input, than the roland preamps will give you.
if you have the channels, and the inputs, depending on how many tracks you can do at once, i'd go into the mackie.... dry, into the vs.
then, mix the drums as you like, with eq and effects, down to a 2-track stereo sub mix.
there's nothing wrong with going through a mixer before it hits the vs, and depending on the quality of your mixer, you can boost the signal before it hits the preamps.... dropping the input value on the input knob to the minimum it needs to get full signal.... and getting a good signal without distortion, from your mackie, is the way to get the highest fidelity into the vs.
that way, the vs preamps and digital convertors aren't having to work so hard, and wont put as much of the 'roland' sound on your input signals.
the next step up from that, would be a digital mixer, and bypassing the vs preamps altogether.....
but you can only go into the vs digitally with 2 mono tracks, or one linked stereo pair.
does that make sense?
me, if i had the mackie, AND a digital convertor, i'd take the kick and snare, run that through a mixer or preamp, send those signals to a digital convertor, and go into the vs digital for those 2 tracks... then send the rest of the kit (overheads, toms, hi hats) to the mixer, and individually out to the rest of the available vs tracks.
if you're a good mixer, you could probably even get away with a stereo output from the mackie mixer (with everything on the kit minus the kick and snare), and the 2 inputs from the snare and kick coming in digital.
that way, you'd only have to use 4 tracks total for the whole kit.
but you'd be locked into your 'stereo' kit mix.......
it's all about being able to re-mix later.
what do you have total, 8 inputs?
Old 02-21-2006
jeff5xo's Avatar
jeff5xo jeff5xo is offline
Dedicated Member
jeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond reputejeff5xo has a reputation beyond repute
Gonzo's right, but be very careful because you won't have as much control when you get down to final mixing. Make sure the drums are mixed accurately when doing it this way.
BOO-YA Studios
If it sounds better after EQ'ing, it works. - Massive Master
Please visit www.gravitycabs.com for a custom LIGHTED guitar or bass cab!!!!
Old 04-14-2006
chestwick91 chestwick91 is offline
Dedicated Member
chestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond reputechestwick91 has a reputation beyond repute
I would say also to record through the mixer...Just the other day i tried doing the same thing....I noticed that it's much easier to go straight through, but harder to get that sound you want....do what that last guy said...thats the best idea
Question about recording wolf70 Recording Techniques 8 06-06-2006 19:14
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
Monitoring existing tracks while recording new ones walpow Newbies 2 12-20-2005 17:39
NY Times article on home recording and soundproofing AlChuck Studio Building & Display 18 04-06-2004 16:46
