Mic Is Too Quiet!
Hey guys, Im using quite a good sounding philips mic -
the problem is that when im recording my drums (i only have one of these mics) i have to put the mic out in front of the drums, to get the full drumkit, but when i play it back on my multitrack program (audacity) it's very quiet (which you would expect, obviously) - but my problem is - if i turn my speakers up it makes it louder and sounds great and is louder - with out distorting it... but if i try to turn it up on my multitrack program it distorts it. I want to have it so its loud with out having people to turn up their speakers every time they listen to the song (im recording the drums for a song for my band). that whole thing might be a bit hard to understand but i hope you know where im coming from so basicly my question is, how can i increase the volume of the track with the same effect i would have from turning it up on the speakers. |
Solution 1: Turn up your speakers. If you like that sound, do it. Couldn't be any simpler than that, huh?
Solution 2: Make sure your preamp gain is turned up enough that you are getting a strong signal, but not clipping either the preamp or your soundcard (peaks should be between -6db and -3db. In your recording software, apply some compression and/or limiting to tame the peaks and allow you to turn up the average volume of the drum track without clipping the master bus. |
Soulution 1: The thing is I have to turn it up ALOT and I want it to be so that when people listen to the song they dont have to turn up the speakers just to be able to hear something.
Solution 2: OK ill experiment with some limiting/compression. |
| Help: Mic Decisions and My Trip to Guitar Center | JohnnyMan | Microphones | 61 | 04-16-2006 22:38 |
| nanocomp better than art tube mic pre? | trdn1 | Other Equipment and Reviews | 2 | 03-11-2006 12:22 |
| FYI - Thinking of getting a Marshall mic - you need to read this! | bvaleria | Microphones | 30 | 10-05-2005 08:16 |
| Beginner's Mic Queries!!! | Ma/T | Microphones | 4 | 07-28-2001 01:26 |
