Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 02-01-2006
bardo's Avatar
bardo bardo is offline
Senior Member
bardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond reputebardo has a reputation beyond repute
Question about the EQ section of the 488
Ok,bear with me now
The spec's read
High shelving 10Khz +/-12db
Mid 250hz to 5Khz +/-12db
Low shelving 100hz +/- 12db
Frequency response 20hz to 22khz
Now my question is,is the frequecy response my whole possible bandwidth?
For example:the high shelving Starts at 10khz to 22khz?and the low shelving Starts at 20hz to 100hz?
I get the mid.I have two controls for that.I it seems from the mid is I can set which freq I want to boost or cut from 250hz to 5Khz.
What I don't quite grasp is the single high and single low.
If I crank up(or down) the high+/- 12db,what frequency am I boosting(or cutting)?
Same with the lows.
Does anyone know the Q's listed for this EQ?
It was not listed in the spec's
Hope I was clear enough .
Thanks for the help.
488 MKII Question David Benson Analog Only 4 02-01-2005 12:24
Question about 488 mk 2 output levels. monty TASCAM User Forum 29 09-26-2004 12:53
488 488 488 488 888888888888??????????? pudgystern TASCAM User Forum 6 05-03-2002 09:20
Newbie question: TASCAM 488 (not MKII) > PC ? Ryasi19 Digital Recording & Computers 4 05-29-2000 11:25
