Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 01-27-2006
fizer fizer is offline
Newbie
fizer is on a distinguished road
Question echo mia soundcard with n-track
So I bought a new echo mia sound card to upgrade my recording. I use n-track, and I do a simulation recording of an audio track, and I hear a hiss. Yet everything is turned off, no mic or anything. When I plug my mic in to do vocals, this hiss is so audible, that I have to use a wave editor to fix the vocal track. Has anyone encountered this problem? Or is it the soundcard? Would another program such as cakewalk be better? I like the ease of use of n-track, but I'm open for suggestions. My mike is an mxl 603, worth around $250. Or does the soundcard pick up the fan noise, if so how can that be rectified?
fizermusic :
Old 01-27-2006
David Katauskas David Katauskas is offline
Supreme Master of Nothing
David Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond reputeDavid Katauskas has a reputation beyond repute
I use the MIA with nTrack and it is extremely quiet.
What pre-amp are you using between your 603 and the MIA?
SoundClick...geezer stuff [Acoustic Rock]
MySpace...enter at your own risk. [Metal Oriented]
Old 01-27-2006
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Yup. The Mia and n-track are not your problem (I used a Mia for a couple of years and it's an excellent, very quiet card.)
Something in your recording chain (or your technique) is most likely the problem.
Old 01-27-2006
daav's Avatar
daav daav is offline
Flailing up a storm.
daav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond repute
and the mxl 603 should cost about $50-70, but that is not your problem anymore i would imagine.
Daav
Old 01-28-2006
Newbie
Hi again, thanks for the feed back. Maybe its techinique, if it is I'd like to perfect this techinque.
My pre-amp is A Tube MP by ART. But as I said, I got noise without the mic plugged in, when I do a simulation recording. I'm getting interferance from something, and I don't know where to look.
thanks for your support
fizer
Old 01-28-2006
Well, the MIA card accepts 1/4" balanced cables. Is that what you are running?
You could also be getting noise from your preamp if it's being cranked too much.
Try this, go into the settings of the MIA card, and set your inputs to +4 and the master to -10 (or maybe it's visa-versa). This will increase your overall signal a bit and may allow you to slightly relax your preamp. Again, check your balanced line from the ART to the MIA. If you're not using a balanced line, then you will probably get noise from that.
Old 01-29-2006
qb2k5's Avatar
qb2k5 qb2k5 is offline
Dedicated Member
qb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond reputeqb2k5 has a reputation beyond repute
What ASIO buffer are you using? I got a tick noise while recording with my Delta 24/96. Thought the card was going dead. Come to figure out my buffer settings were too low. Do you get the hiss noise thru your speakers and headphones?
My rap artist page....
Old 01-29-2006
Newbie
computer noise when recording
So I downloaded a trial multi track recording program, something like n-track,(which I use) to try a differnt approach to the hiss I hear when recording vocals. Its all the same. I cannot find the origin of this noise. Its like a tape hiss before you apply dolby. I'm really frustrated. Are there anymore ideas out there circulating?
Old 01-29-2006
2.5K Gold Member
If you are getting noise with NOTHING connected to the soundcard it has to be in the computer.
If you have a desktop, try moving your soundcard to another slot.
More info on your computer would help (we're not psychic...)
Old 01-29-2006
Newbie
response to tim obrien re:computer noise when recording
So its a ASUS k7V slot A motherboard has 1GHz AMD Athlon tm processor Support, 100 g hard drive. 384 mb of ram. I run surround sound speakers. When I bought the echo mia sound card, It wouldn't install without my soundblaster live card being in place. (I upgraded from soundblaster live to echo mia) so I needed to leave soundblaster in the computer. I run xp pro. I had the same problem with noise when I had soundblaster live, and I was running windows ME. That was one of the reasons for upgrading to echo mia soundcard. I've tried everything other than a standalone soundcard, but its kinda late for that, because I bought this echo mia. Must be something wrong somewhere, if no one else has that problem.
Old 01-29-2006
2.5K Gold Member
Hint: The trick to installing the sblive and mia together is to pull the cards and delete the drivers for both. Install the Mia and get it working, then install the sblive. (I used to run a Mia and SBLive together too... although once I found that soundfonts run great and sound better through the Mia with a soundfont player like rgcaudio.com's SFZ or Bismark, I dumped the SBLive from my PC.)
Are you SURE you're not picking up fan noice from the PC??
  #12
Old 01-30-2006
Newbie
re fan noise
Fan noise was my concern, if it is, other than going to a quiter fan right away, how can I test it? Can I unplug the fans for a short time?
fizer
  #13
Old 01-30-2006
2.5K Gold Member
Move microphone as far away from CPU as possible.
Point back of mic toward CPU.
Don't unplug your fans unless you want a puddle of silicon where the chip used to be...
  #14
Old 01-30-2006
Newbie
Exclamation re: noise
Thanks for your help.
fizer
Audition CD Track info problem. Rossco Cool Edit Pro / Adobe Audition Forum 1 01-18-2006 14:13
Sonar and ECHO Mia soundcard tcdave Cakewalk / Sonar Forum 2 08-05-2003 12:06
will I still be able to use midi with the Echo Mia? deemic Digital Recording & Computers 3 07-12-2003 22:27
Anyone using Echo MIA with VIA chipset? warble Digital Recording & Computers 2 07-01-2003 06:52
Echo MIA or equivalent nosmas Digital Recording & Computers 6 07-19-2001 19:08
