Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-26-2006
Jfallin Jfallin is offline
Newbie
Jfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these partsJfallin is infamous around these parts
Drum Machine recorded to the comp...
I need help getting the parts from a external drum machine into Pro Tools on the comp...the drum machine is a Dr-3 and i have no idea how to get it on the computer. With answers Treat me like i'm retarded...very detailed
Thanks
Old 01-26-2006
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
Do you have a MIDI input for your computer?
Why not just send the MIDI signal into the computer, and then use the computer's internal sounds?
That will be your best bet for sound quality.
Tim
Old 01-27-2006
Newbie
no sir i do not
Old 01-27-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
The best way to go (and I dont use protools, so if this is possible I dont know, PT has always been very weak when it comes to midi) is to just slave the drum machine to midi clock and then just record the midi notes (or sounds) when the squencer plays back (it will be syncd to the project)
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 01-27-2006
aznightwolf aznightwolf is offline
Newbie
aznightwolf will become famous soon enough
What inputs do you have on the comp?
What outputs does your DM have?
Old 01-27-2006
GreenDank GreenDank is offline
Dedicated Member
GreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond reputeGreenDank has a reputation beyond repute
I get the idea you just want to record the drums onto a track in pro tools. Come out the headphones out and go into the computer's line in. I guess you could use a preamp or mixer in between the drum machine and computer, but might not be necessary - I think they pump out some good volume, but I'm not sure.
You might need to go to radio shack and get the appropriate adapter jacks or cords, depending on the size of the input/output. Usually 1/8 to 1/4 inch (or vice versa) adapters. Unless you have a 1/8" to 1/8" cord. Most people have 1/4" cords laying around, hence the need for the adapters.
Sync drum machine and SL? PT76 Cubase User Forum 5 12-28-2003 17:27
How do I set up(mix) the Mixer & Drum machine before Recording? PaulKarate Mixing / Mastering 3 11-06-2003 16:13
Advice on Drum Machine jwai Drums and Percussion 7 03-23-2003 21:42
Why do I hear my drum machine? Eisenbart Cakewalk / Sonar Forum 6 06-18-2002 06:29
Sequencer to drum machine? Alan McGuinness MIDI Mania 7 06-03-2002 07:49
