what are sample rates for?
just started using audition for recording, need to know what sample rates are for?
hmmm...
so the higher the sample rate...the better the quality? so i should put the sample rate to its highest? |
That all depends. If you're doing a home recording and the final product is going to be a CD, your best bet would be 44.1 kHz sample rate at a bit depth of 24 (assuming your sound card can do 24-bit). If you're doing audio for a DVD, you want the sample rate to be 48 kHz.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
ok yea im doing home recording for my vocals. how do i get these settings in audition? |
Your manual should say... If you don't have one... Try F1...
When you open Audition, go to File/New Session and a box will come up that allows you to set the sampling rate and bit depth.
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23 |
then whats a good setting to record my vocals?
Honestly, 44.1k and 16-bit is the simplest and most accessible way to record your vocals (mainly because those are the same specs as a compact disc). However, if the quality is unsatisfying, then up the bit and sample rates (but after your production you can always "export" to 44.1k / 16-bit to burn your CDs. Experiment if you have the time...
| The Skinny on Tracking, Mixing and Mastering at high sample rates | LRosario | Mixing / Mastering | 7 | 11-27-2005 22:25 |
| Sample rates problem on VST32 | SpotlightKid83 | Cubase User Forum | 0 | 02-24-2005 23:41 |
| sample rates, dithering ETC | GamezBond | Mixing / Mastering | 2 | 01-30-2005 20:53 |
| Optimising audio at low sample rates? | Agent47 | Digital Recording & Computers | 1 | 07-02-2004 03:53 |
| Synths, sample rates and more.... | Alchemist3k | Digital Recording & Computers | 1 | 11-01-2001 14:55 |
