How do you dampen your kick drum?
Pillow? Foam? Tape?
i got a blanket in there
sesame street ABC's
My Band: Aqueous - www.aqueousband.com |
Evans E-MAD head. Before thos came out, just tune it low and put a (one) pillow in it.
Remo Muff L and a pillow.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
Evans also makes these little pillow looking things that lean up against the heads. When you hit the drum, they bounce a little. That lets the head resonate for a second before it stops. So you get the low end of not having it muffled while still having some control.
http://www.myspace.com/onebadassdude |
I don't.
It all comes down to flapping paper in the end. |
I go back and fourth between Evans Emad (batter and reso) or just a well placed pillow.
I have an EQ3 with a retro screen reso (Evans)... when you have those two, you don't need any more muffling.
"However Simon thought of the beast, there rose before his inward sight the picture of a human at once heroic and sick."- Lord of the Flies |
on two of my kits, i use a remo powerstroke III head with a felt strip on the batter side running vertically on the left side.
tell me... is it more of the same and where can i find it? |
Another resounding vote for EMAD!
#12
I only dampen when I record.
It's hollow live. It sounds good and is louder. Remo PSIII baby
You can't change the world, but you can change yourself- Sick of it All |
#13
4 lbs of pinto beans sewed up into a half a pillow case...
#14
I have a small pillow in it that barely touches both head. Its a really flat pillow also, but mostly, its all about tuning. Remember, the bass drum is a DRUM as well. You have to learn to tune it properly so you can get a killer sound out of it without muffling the hell out of it.
#15
I try to use as little as possible. I see a lot of guys that wind up with a 10'' tom after all the packing goes in. |
#16
i have a remo pinstripe skin, lugs tignt enough so theirs no ripples and 1 pillow inside
SM57, SM58 Audix D6 Samson 7 Mic Kit Bunch of Crap Mics Crate 12Ch Mixer Yorkville 12Ch PA Mixer Pentium 4 2.0Ghz 768Ram Yorkville YSM2P Studio Monitors Creepcore Records http://www.myspace.com/creepcorerecords |
#17
EMAD!...very nice...nothing in my kick drum anymore!...has anyone here used the emad reso head yet?
shortness scott swatzell http://www.myspace.com/upperroommusic2006 |
#18
. Ron Paul At these times it is good to be on friendly terms with reality. Drummer Portal LinuxGuruz |
#19
We've been using Aquarian Superkick Is and IIs lately -- with no additional muffling. They work very well for recording.
http://www.aquariandrumheads.com/pro...play.asp?id=11 Cheers, Rez |
#20
Wide open...EMAD without foam inlay, just slight dampening from the plastic ring. Fiberskyn on the reso; no hole. Beta52 about three inches from beater impact and about 20 degrees off axis. Both heads fairly loose.
#21
I use a small bass drum muffling pillow. It's made by Protection Racket. It works really well.
It's a bit like the Evans one mentioned. It bounces off the head when you hit it, and falls back onto the head shortly after to dampen the sound. |
#22
If I have too I just use a towel.
#23
My drummer - Evans EMAD with the foam strip, Evans EQ3 reso head. Still a little live for recording, though.
Me - in my 20" kick - generic heads, very loose, one pillow (it says "soft" so you know that it is). Lots of punch. In my 22" kick - Evans EQ2 batter with kickpad, EQ3 reso. Again, this is a little live for recording. If I'm going to close mic a kick, I'll use my 20.
Let's dispense with all the philosophical high-minded reasoning and well articulated thoughts and get down to some good old name-calling and insults! |
#24
I like the Evans pillow thing that velcroes to the inside of the drum.. it stays put and is easy to adjust....doesnt shift like pillows tend to do.
#25
like a tube amp on 3
| my kick drum hell..cured! I think | jmorris | Drums and Percussion | 2 | 02-25-2007 00:56 |
| Question about mixing Kick drum | Mike_W | Mixing / Mastering | 13 | 03-01-2003 09:19 |
| Tuning kick drum batter head for good beater response. | Uladine | Drums and Percussion | 2 | 07-25-2002 08:47 |
| good overhead and kick drum mic placement..... HEEEEEEEEEEELP!!!!!!!!!! | ZEKE SAYER | Drums and Percussion | 4 | 07-16-2002 20:42 |
| "Airy" Kick Drum | moelar2 | Recording Techniques | 3 | 07-04-2001 20:14 |
