Old 01-22-2006
PHILANDDON PHILANDDON is offline
Senior Member
PHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud of
Analog Newbie-Fostex A2-Easy Questions
Hey,
So I've recorded a song on the Fostex A2, I picked up on ebay and I gotta say it sounds pretty good (considering I was just experimenting with the deck and paid no attention to mic placement or performance). A couple of quick questions:
I'm coming out of a preamp (and not a mixer) into the recorder. What should I do with the input levels on the recorder? Should I put them at 12 o'clock? Turn the up (or down)? Where should I try to be metering on the recorder? I'm recording voice and guitar...live, no overdubs. Thanks.
Oh, and when I make a digital copy of my recording to make a CD, I'm guessing I press the "repro" buttons on the recorder and just hit play. Am I right? I noticed that when I made a digital copy with the tape-recorder's input buttons pressed in, I gotta kinda a 50'sish echoey effect. Kinda cool. Kinda slap-backy. What's that about?
THANKS
Old 01-23-2006
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
No-one else has offered yet, so I'll try to help.
Generally you'll want to have the meters hovering around 0. Some people like to slam them into the red. Try both approaches and see which works best..
Alas, this is only an easy question for people who have an A2. The A8 is similar, but not similar enough in this regard. I would have thought that what you're doing was correct.
I don't know how you're getting the echo. How many heads does the A2 have? Is it two or three? I assumed it was two, but you can only get echo on a three-head machine. If there are three heads, it is possible to switch it into 'sync' mode, and take the input off the record head?
Are you absolutely sure that you aren't somehow taking the feed off both the record and repro heads?
Old 01-24-2006
Senior Member
Well maybe the A2 is a three-head machine cause it appears to have a couple "sync" buttons. So maybe I hit the snyc button on playback and got the echo effect. Sounds kinda good though, I think.
Thanks for the help.
Some newbie questions about recording vocals... Xpred Newbies 14 12-10-2005 22:09
Mixing Down Questions from a Newbie Reg3n Newbies 8 11-03-2005 18:24
Fostex 16 track analog macula56 Analog Only 3 03-14-2005 17:18
VF16 interface function questions explained by Fostex jvdw Fostex Forum 0 08-03-2000 13:26
From Analog to digital: Lotsa newbie questions zommbee Digital Recording & Computers 2 06-01-2000 18:12
