Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-21-2006
rediflight rediflight is offline
Newbie
rediflight is on a distinguished road
kick drum problem
I cant get my kick drum to sound good. I've tried a couple of different placements but it still sounds like a rubber kick ball. I have a D112 and am still new to recording so I'm sure its something stupid that I am not doing right. Any placement and EQ tips?
Old 01-21-2006
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
Check your tuning. And then check it again. Seriously, making sure it is tuned well can make a HUGE difference. If it is already tuned, try tuning it differently. What kind of sound are you after? That will affect what advice you will get, as well.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 01-21-2006
Newbie
I'm going for a deep tone, lots of double bass stuff. I play in a metal band if that helps. Any specific tuning advice?
Old 01-21-2006
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
When you say "rubber kick ball" are you referring to a sound like a high "sproing"??? (best anomatapia I can think of...)
Are you using one head or two?
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 01-22-2006
cobradenim's Avatar
cobradenim cobradenim is offline
Senior Member
cobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond reputecobradenim has a reputation beyond repute
What kind of wood is the drum? Where is the mic placed? Place the mic outside of the drum in front of the sound hole and you'll capture more of the actual kick sound rather than the "ball" sound you get when you stick the mic inside the drum.
It also depends on the shell size and head/tuning combination.
Old 01-22-2006
FunkDaddy's Avatar
FunkDaddy FunkDaddy is offline
Senior Member
FunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond reputeFunkDaddy has a reputation beyond repute
If you're doing a lot of double bass stuff you're going to want that "rubber kick ball" sound (I'm assuming it's the impact "click" type sound) or your double bass work will get lost in a sea of muddy bass drum. You can always EQ in a bit more bass to the sound. I'd want to keep the impact sound though, especially for metal/double kick.
Old 01-22-2006
fritzmusic fritzmusic is offline
Senior Member
fritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond reputefritzmusic has a reputation beyond repute
I think I know the sound you're after. First off, the most common bass drum recording error is either too much or too little dampening. In your case, it sounds like too little dampening going on.
For metal sound (and to stay away from the rubber ball sound):
- Mic on the batter side.
- Boost 1k-4k frequencies signals before they are recorded to get more of that "clicky" beater definition sound like Pantera or ...And Justice or what have you.
-experiment and keep repeating until you get the sound you want.
-Use hard beaters (not felt) although the difference may be subtle to your ears, it's the world of difference to the mic.
-You can try those spot pads (you can find at any music stores) you stick on to the batter area of the bass drum to get even more definition. IF that still doesn't work...
-I illustrated a bass drum "click trick" to get that nice, fat clicky sound ready for a mic. This is something I stumbled upon a few years back. Download the image I attached to this post. Basically, you take any old broken drumhead you have lying around, loop pieces of duct tape sticky-side out, stick it on the bass drum batter side to batter side dead center of where your beaters hit. Just don't put tape on your bass drumhead where the residue left behind can catch your beaters.
-Tune the kick drum up or down according to the key the song is in, making sure that the tuning works well with the bass guitar.
-Eq: If you need more bottom end, try boosting 60 to 100Hz. Try rolling off lower mids (300-700Hz) to get rid of a box or bouncy ball-like sound.
-You should try an Evans EMAD head on the batter. It's the quickest way to that beefy "metal" sound out of your kick in my personal opinion and I've tried every bass drum head under the sun on many different kits in pursuit of that venerable metal sound on the quick.
Old 01-22-2006
Newbie
They are Pearl Exprot series drums (I'm not sure what type of wood they ues) and I had the mic placed just inside the drum pointed at the beater.
Old 01-22-2006
Newbie
I dont think there was anything inside the drum when I recorded (if thats what you mean by dampening).
What do you mean by "Boost 1k-4k frequencies signals"?
Sorry I'm sure thats a newbie question.
Old 01-22-2006
emergencyexit's Avatar
emergencyexit emergencyexit is offline
Dedicated Member
emergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond reputeemergencyexit has a reputation beyond repute
Fritzmusic,
Im pretty sure he doesn't have any rack EQ since he is new to this. And as for having a board with EQ on the channel strip, well there isn't much you can do with that for specifics.
Here's the real question from me. Do you like the sound of your drum before you record? Just live and to your own ears. If it doesn't sound good there then there is no way its gonna sound good anywhere else. But if it does sound good there then micing it will be very easy. Maybe you could post a clip of what it does sound like?
Ben
http://www.emergencyexitmusic.com
Old 01-22-2006
Newbie
yeah it sounds ok, im sure if i mess around with tuning and dampening and stuff i can tweak the sound a little bit more. i have a dbx 2 channel 15 band rack mount eq that i use for my guitar, is there any way that this could help with my eq issue?
  #12
Old 01-24-2006
tom5 tom5 is offline
Newbie
tom5 is on a distinguished road
I know that rubber ball sound you are talking about. I got it when i tuned too high, without muffling of anykind. Just tune alot lowerand try some muffling techniques such as taping a twoel to the batter from the inside.
  #13
Old 01-24-2006
seryozha's Avatar
seryozha seryozha is offline
Dedicated Member
seryozha will become famous soon enough
yeah....you prob. have it tuned way to high. I tighten my lugs on the batter side just so that there arent any ripples in the head and do the same with the other. And then you put a pillow or blanket in the drum so that it touches both heads.
AD Baculum!
Drum Problem Fry17 Mixing / Mastering 3 11-12-2005 20:46
Kick Drum Beater Issues Scottgman Mixing / Mastering 13 10-13-2005 08:57
erratic kick drum phosos Mixing / Mastering 13 10-07-2005 08:53
Kick Drum Mic and My Set Up zackformula Microphones 6 01-22-2005 22:28
Kick drum seems to be lagging on final mix Joel76 Drums and Percussion 6 03-07-2002 16:51
