Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 01-19-2006
marvkan marvkan is offline
Newbie
marvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond reputemarvkan has a reputation beyond repute
bypassing tascam fw1884 preamps
Does anyone have the definitive method of bypassing the internal pres without having to go adat lightpipe?
Old 01-24-2006
sekhmet sekhmet is offline
Newbie
sekhmet is on a distinguished road
Hello, I think I've read somewhere (probably in the old tascamforums board) that turning the input trims all the way down bypasses the fw1884 internal preamps.
Of course you'll need an external preamp because your signal will be too weak, but I guess that's your main goal
Old 01-25-2006
deepwater deepwater is offline
1K Silver Member
deepwater has a spectacular aura aboutdeepwater has a spectacular aura aboutdeepwater has a spectacular aura about
The only way to do it is to use the spdif or adat inputs and for that you will need an A/D converter unless you have something like the M-Audio Tampa with digi outs.
The most popular HR member - just do a search
Old 01-27-2006
Newbie
bypassing my fw1884 pres
Thank you for your responses. Since I placed my post, I called Frontier Designs who designed the interface with Tascam. You are correct in saying that an a/d would be required connected to either the spdif or adat interface would be the only way to bypass the internal converters. Frontier also informed me that without a/d conversion, the preferred method would be line or insert, they suggested that sonically both methods are the same (not much difference) except that using inserts is an unbalanced input, so I will use line (there will still be some audio artifacts from the interna pres)l but if the gain of my external pres (Groove Tubes The Brick) is set hot enough and then turn the Tascam pot incrementally until the signal from The Brick is appropriate, it should do the trick. I tried it out and the results are much better. I'm sure in the near future, I'll just add a good a/dd/a in the front end. One last thing, Frontier informed me that I shouldn't invest in any of the mid priced units (RME etc.) becuase at 96k there won't be a "WOW" difference, thay suggest holding out until I can afford Apogee, Prism etc. at 192k.
Tascam FW1884 / FE-8 would it work for my circumstances? slash81291 Mixing / Mastering 1 11-22-2005 11:15
Preamps in an older Tascam M-208 mixer? G. Simon Newbies 0 10-24-2005 12:37
cakewalk home studio 2004 and tascam us 428 problems lonman Cakewalk / Sonar Forum 5 11-02-2003 06:06
How important are preamps? (Tascam 424MKIII) SeaOwl TASCAM User Forum 5 10-18-2003 01:02
Tascam.com: I KNEW it Mark7 TASCAM User Forum 45 10-16-2003 02:30
