Old 01-19-2006
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
need help w/signal path
Question for the pros:
Here's my typical recording path:
Microphone into
True Systems Precision 8 into
RME Fireface 800
I want to start using a FMR RNC in the chain to tame the peaks of a new vocalist who is not really trained in proper mic techniques.
So the BIG question is:
Where in the signal chain do I put the compressor?
Keep in mind the RNC is unbalanced.
Please help. Tnx, Rez
Old 01-19-2006
Carter's Avatar
Carter Carter is offline
Total gear slut
Carter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond reputeCarter has a reputation beyond repute
Microphone into
FMR RNC into
RME Fireface 800
This is how I would set it up, but someone else will come along and offer different ideas.
Carter
MCF Productions
Old 01-19-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I don't have your exact same system, but if you want to track with some compression, do it as Carter stated. I do mine like this....mic-pre-RNC-Delta44. I am not a good vocalist, and use some compression on the way in, for those reasons.
I won the internets......
Old 01-19-2006
LeeRosario's Avatar
LeeRosario LeeRosario is offline
"The Ears"
LeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond repute
Originally Posted by Carter
Microphone into
FMR RNC into
RME Fireface 800
That's about right
Normally you would see something like Mic -> pad -> polarity -> preamp ->
and then after that you can sort of mix and match.
In this case, the signal flow isn't complicated, so it would come right after your preamp stage.
"ghost" producer/Engineer
The Demure on ITunes
Old 01-19-2006
Big Kenny Big Kenny is offline
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
Yep, the true has nowhere for a side chain so that is your only option
(I am not familiar with the fireface, can you insert there?)
In His Name
Big Kenny
Old 01-19-2006
RezN8's Avatar
Thanks!
Thanks guys for helping me confirm my initial thoughts.
"(I am not familiar with the fireface, can you insert there?)" -Big Kenny
Using the Fireface was another possibility. Here was my other option:
Mic to Mic Pre out to Fireface In (Channel 1)
Within RME's Total Mix matrix:
Route Channel 1 to Channel 7 Out
Channel 7 out patched to RNC In
RNC Out patched back to Fireface Channel 7 In
Record Channel 1 AND Channel 7 so I have both a compressed and uncompressed (pure) signal. Overkill? Probably... but better to have it and not need it then need it and not have it. ;-)
Old 01-19-2006
Carter's Avatar
Total gear slut
Yeah that will work too! two different flavors on one vocal. but there is alot of ad/da going on.
Carter
MCF Productions
Old 01-19-2006
I'd be wary of that many conversions
In His Name
Big Kenny
Old 01-19-2006
Carter's Avatar
Total gear slut
I agree, thats why I included that in my comment!
Carter
MCF Productions
Old 01-19-2006
RezN8's Avatar
A/D to D/A to A/D ... and that's why I was askin' the pros!
I'll try to do a test tonight just to see if there are noticeable artifacts.
Thanks again! -Rez
DirectX Plugin Path Bonz Cubase User Forum 4 08-18-2005 16:11
Upgrade to vocal path - RNC or Envoice or Green5 or ...? coloradojay The Rack 12 02-18-2004 15:24
Miss Audio Path A1A2 Cakewalk / Sonar Forum 25 12-22-2003 15:07
mastering signal path audioarts Mixing / Mastering 16 07-07-2003 10:04
Do I have an upgrade path? Eurythmic Digital Recording & Computers 2 10-06-2001 14:18
