Newbie post..mixdown equalization & levels
This is my first post here and I just wanted to say hello to all.
I have a question concerning final mixdown equalization & levels. I'm using a set of roland MA-8 monitors and I am having trouble trying to establish the correct EQ curve for playback on a standard stereo. When mixing I try to be careful not to over accent the bass but still achive a good sounding mix....well it sounds great on the computer but when I make a CD and play it in the stereo it sounds like the bass is on steroids. Not anywhere near RIAA standards. I'm also having trouble getting enough voulme on the CD. I have to turn up the stereo's volume control up quite a bit more than factory CD's. Any suggestions would be greatly appreciated. Thanks, Moptop |
Anybody?
No one has any suggestion?
At the risk of being perceived as "rude"...
This has been covered over and over, and all the replies say the same thing:
USE YOUR EARS. There are no "presets." What you have to do depends on the sound of your room, how the monitors interact with the space, what sound you are trying for, and several thousand other things. There may be a few people here with experience with the particular monitors you use (for example), but not in your acoustic space. Experiment, and make a note of what works, and what doesn't. There's a lot of information available at this site, but not much on magic bullets. Every room is different, the gear in each one is different, the recordings are of different music played by musicians of widely differing taste and ability, and the musical goals are different. And you're different from each of us. Did I mention, every song is different? I was reading a thread at a pro engineer forum site the other day, and the question of "presets" came up. It turned out that the only one anyone used was a highpass filter set at 150Hz to kill the tubbiness from the room. So try things and listen. Believe me, this is the fastest way to improve. Burn your mixes to CD and carry them around. Play them in your car, in your boombox, your Walkman. Also, read the threads here. I myself come here to learn, rather than pontificate (believe it or not).
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23 |
Yea...I remember that one time when you pontificated....it sucked.... ![]() by the way...what is pontificate? ![]() |
Etymology: Medieval Latin pontificatus, past participle of pontificare, from Latin pontific-, pontifex
1 a : to officiate as a pontiff b : to celebrate pontifical mass 2 : to speak or express opinions in a pompous or dogmatic way
..or to generally act like a pratt!
Stephen |
| Sounding good at the right levels | sjoko2 | Mixing / Mastering | 29 | 02-03-2006 18:43 |
| For the 1000th post. | dragonworks | Songwriting, Singing & Vocals | 7 | 07-16-2001 10:44 |
| Post a good mixdown compressor- under $1,000 | cerealchamp2000 | The Rack | 7 | 05-12-2001 08:56 |
| suggestions on volume levels in cakewalk for a multi-track song (see post) | MegaGoo | Cakewalk / Sonar Forum | 9 | 04-21-2001 13:38 |
