record monitoring
hi there,
i am trying to do some vocal recording into acid. i am fine with getting signal, etc., but my question is about monitoring during the recording. what happens is i am hearing the master mix in stereo but my incoming vocal/guitar only comes back panned hard to the left (which is the channel i am using from the mic pre...) after the recording is finished i get the vocal (or guitar) track playing back in the center and i can pan at will. however i cannot get the vocal track to be in the center while i am monitoring the recording in real time. i guess if i had a mixer i could figure out a work around, but right now i am limited to my indigo io laptop soundcard... is there a way to send the incoming recorded signal through another bus or something in order to be able to adjust pan/volume? in the past i used a tascam 788 which had a seperate cue mix for this type of stuff...anything similar in acid 5.0? ps- tried to read the manual but couldn't find an answer, and i also realize that acid is not necessarily optimized for audio recording. just wondering if i am missing something... thanks peace |
| NEWBIES using stereo sound cards Article on how to set up your monitoring. | manning1 | Newbies | 10 | 01-08-2004 05:19 |
| Monitoring equipment: some unconventional wisdom | jeffree | Other Equipment and Reviews | 16 | 10-27-2003 18:57 |
| Finally ready to record 170 children, in groups of 10...mic question remains. Advice? | Julia | Microphones | 92 | 12-29-2002 11:19 |
| Niles Rogers on rec'ing guitars | blipndub | Guitars and Basses | 5 | 12-07-2002 13:02 |
| 2 Qs: lecture recording and video record (analog) | asf131 | Newbies | 7 | 11-20-2000 20:17 |
