"Airtight" bass traps why?
Why exactly is it that sealing bass traps "airtight" is so important? Is it to stop sound spill or something else? Thanks for any help you can give me! -Jingleheimer-
the fibers of which you don't want free floating in the air, as they may be harmful if you breathe them in.
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
The enclosure of the bass trap (mechanical) has to be sealed for it to work right.
I was under the impression you could just use a thick broadband style absorber around 4-6" across the corner.
as one "bass trap" would be mostly home made fiber "panels", and the ones needing to be "airtight" would be mechanical and/or manufactured specialty items.
I edited my above post for clarity, and it refers to the mechanical type (pressure absorber) vs the fiber panels accross corners (velocity absorber). In the latter case, you wound not want it to be airtight, as the sound must pass into it to be absorbed.
If it is sealed, when the plywood face vibrates, it forces the air inside the trap to move into and out of the fiberglass panel inside, which dampens the vibrating plywood and soaks up the energy. If it was not airtight, the air would just move in and out the holes, and the plywood would not be dampened, so would just vibrate until it stopped on it's own (sending all that energy back into the room until it did).
| Possible DIY corner bass traps? | jabulani jonny | Studio Building & Display | 2 | 12-13-2005 12:13 |
| bass traps | antispatula | Studio Building & Display | 5 | 12-06-2005 07:39 |
| A little mix before my DMP3 & Bass traps | jeff0633 | The Rack | 0 | 04-03-2004 01:45 |
| aardvark direct pro user.... Advice on recording DI Bass needed | Rassoodocks | Recording Techniques | 13 | 06-24-2003 07:09 |
| Auralex LENRD bass traps | mncheetah | Studio Building & Display | 1 | 04-07-2002 16:48 |
