Old 01-16-2006
ericlingus ericlingus is offline
Force of Nature
ericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond repute
Connecting the RNC
How would I connect the RNC to my rig. I hook up my guitar to v amp2 the outs on the vamp to the line ins on my firebox. Where does the RNC go?
Old 01-16-2006
Big Kenny Big Kenny is offline
Been Here, Posted That
Big Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond reputeBig Kenny has a reputation beyond repute
I've not used the rnc for an effect on guitar but if it is like any other compressor for guitar you go thru the compressor first, then on to the rest of your chain
In His Name
Big Kenny
Old 01-16-2006
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
guitar is intstrument level; RNC and firebox are line level; the vamp converts instrument level to line level I assume; so the RNC would go in between.
Old 01-16-2006
Force of Nature
but how exactly. What cable and where do I insert them?
Old 01-16-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Put from V-amp=1/4" to in on Compressor. Out on compressor to in on recording device. Should all just be 1/4 inch jacks, for a guitar.
I won the internets......
Old 01-16-2006
Force of Nature
thanks a lot.
Old 01-16-2006
Force of Nature
I hear about Y cables a lot when connecting external effects.
Old 01-16-2006
Force of Nature
Old 01-16-2006
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
You need a Y cable to connect an effect to the Insert patch point on a channel strip. That's not what you're doing, so don't worry about getting one.
Old 01-19-2006
Force of Nature
on tweaks guide it says this? If this is the case I need another preamp! ahh. An important tip for those going mixerless: Before you buy an audio interface with built-in preamps consider if you will ever want to add a compressor. If you think you will, make sure the audio interface has inserts or sends. If it does not, there will be no way to add a compressor to the rig without buying yet another preamp.
I have the firebox. Which doesn't have inserts. Just line ins.
Old 01-19-2006
Silverwulf Silverwulf is offline
Newbie
Silverwulf is on a distinguished road
If you like your Firebox, you could always pick up a Firepod for not much more. An extra 6 mic pre's, and it has line inserts on the first 2 pre's for compressors, EQ's, etc.
  #12
Old 01-19-2006
Force of Nature
well the problem with that is I don't want to spend another 6 hundred dollars on something I don't need except for the inserts. I guess i'll have to get a pre amp or something. Or maybe I can hook it all up still. Anyone here know whether or not I can still hook up a compressor,expander and EQ to my rig. It's Vamp2,firebox into cubase LE.
  #13
Old 01-19-2006
Newbie
Sent you a PM with some affordable ideas...
  #14
Old 01-19-2006
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
You don't really need an outboard compressor or EQ for recording with a V-AMP. I have been recording direct with the V-AMP 2 and then the V-AMP pro for a couple of years with good results.
The V-AMP has an onboard compressor that can give you some limiting help going in, and then EQ on your PC with a plugin. It is really that simple. Two 1/4" Line outs from your V-AMP (really only need two if you are using stereo effects like delay or rotary speaker) into two line ins on your firepod. That's it man. Set your V-AMPS volume so that you are peaking comfortably below 0db, then hit record.
If you are not getting a loud enough signal, then something is wrong with your DAW, or the V-AMP. If you are clipping your converters, then turn the V-AMPs volume down, and or use more onboard compression. It makes no sense to spend money on an external effects to use with a modeler - you are still only running modeled sound through it.
  #15
Old 01-20-2006
Force of Nature
yeah but I would still like to have that option
  #16
Old 01-20-2006
amra's Avatar
1K Silver Member
In that case, see dogmans post above - that's all there is to it.
  #17
Old 01-20-2006
firby firby is offline
Senior Member
firby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond repute
This is wrong. You can still do hot inserts with a normalled patch bay. Just wire your stuff to a patch bay and make your own insert points. All an insert is is a point where a an signal can go through another device before hitting the line input on your whatever.
Well I guess it is only half wrong because your input could be a microphone in which case you would still need to to amplify the signal to line level before you could insert it into most of the devices you want to put it into ie a snare drum going into a preamp then inserted into a compressor and then going through channel eq and what not. So yeah guess so.
I am glad I have a nice mixer with 24 inserts.
  #18
Old 01-20-2006
Force of Nature
I said WITHOUT buying anything extra. With just what I have, is it possible?
Im selling my RNC (Really Nice Compressor). Nilbog Free Ads for Music / Recording Equipment 5 01-21-2006 02:56
RNC (compressor) questions jobones The Rack 6 08-29-2003 13:45
RNC Hookup bmeador The Rack 12 01-14-2003 19:02
using an RNC with a Studio Projects VTB-1 saag paneer Recording Techniques 5 11-13-2002 22:32
Just recieved my RNC... Beathoven The Rack 4 09-15-2002 09:42
