Old 01-15-2006
jwgeetar's Avatar
jwgeetar jwgeetar is offline
Dedicated Member
jwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond reputejwgeetar has a reputation beyond repute
Question powered Crate moniter dead---need crossover help!
hey all, my Crate APM75 powered PA moniter died. About 6 years old, i tried everything to get it going but somethings blown. Instead of fixing the power amp side, i just want to make it a regular speaker & horn moniter.
Ok, my speaker tech here said he could do that by installing a passive crossover in it for $40. Sooo, my question is---how hard is it to install my own crossover in it? and which one do i need for this "particular" model?
Anybody familiar with this? thanks yall.....jw
Beauty is in the eye of the Beerholder-jw weir
http://jwweir.com
Old 01-15-2006
Mindcore's Avatar
Mindcore Mindcore is offline
Senior Member
Mindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant futureMindcore has a brilliant future
There are more knowledgable then me, but I can give you the basics.
Installing a passive crossover is very easy, its just a small box that you'll screw to the inside somewhere.
I did a quick search, so you should confirm the settings, but it looks like the crossover is set to 2.5khz so you would need a crossover that either meets that, or is adjustable.
wire the woofer to the "low" side horn to the "high" side, and attached your input wires. Done like dinner.
HTH
IF... The Website
Old 01-15-2006
jwgeetar's Avatar
Dedicated Member
HTH
thanks MC, that's what i'm looking for. Should i yank out the Amp part with the Eq and chunk that part?
http://jwweir.com
Old 01-15-2006
Mindcore's Avatar
Senior Member
Well, if it doesn't work, I can't see why you'd want to lug that extra weight around. Plus, if you have it out and sitting around, one day you might get tired of it and get it fixed. Sad, but its happened like that for me before.
The signal is not likely getting to the EQ, so it really serves no benefit.
IF... The Website
Old 01-15-2006
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
$40 to make and install a crossover sounds fair, since that's roughly what it'll cost to buy a crossover alone (see first link). If you're going to scrap the EQ, you may want to have at least some control of the HF unit (see second link).
1. http://images.google.co.jp/imgres?im...500_500.jpg&im
2. http://images.google.co.jp/imgres?im...l%3Dja%26lr%3D
Best scenario would surely be to just get the thing repaired, wouldn't it?
Old 01-16-2006
jwgeetar's Avatar
Dedicated Member
yea, i really do hate hauling it around--big and bulky. i was aiming to make it another main speaker to replace my 15 year old Peavy speaker. THEN--- get a hot-spot moniter. i never liked hot-spots before but they have improved and they are light to carry and setup....
After seeing that $79 crossover robin, the $40 deal from my tech may have to do.......!
stay tuna----
http://jwweir.com
Old 01-16-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
You don't need to buy a $79 crossover, you can get a preassembled unit for $20 from Parts Express:
http://www.partsexpress.com/pe/showd...number=260-142
If you build it using those parts, it's cheaper still.
Or you can save cash by using a 6dB design (half the parts), or go even cheaper and use electrolytic caps.
The most basic design (assuming 8 ohm drivers):
Into the tweeter:
http://www.partsexpress.com/pe/showd...number=027-338
or for poly:
http://www.partsexpress.com/pe/showd...number=027-426
Into the woofer:
http://www.partsexpress.com/pe/showd...number=260-723
You might also need to pad the tweeter, as mentioned that can be done with a couple of resistors, but you'd have to know the right values, or spend more and buy an adjustable L-pad:
http://www.partsexpress.com/pe/showd...number=260-250
Or for $1 total, a 6dB pad is probably a good guess, that would be this in series:
http://www.partsexpress.com/pe/showd...rtnumber=017-4
And this in parallel:
http://www.partsexpress.com/pe/showd...rtnumber=017-8
Old 01-16-2006
jwgeetar's Avatar
Dedicated Member
Into the tweeter:
or for poly:
Into the woofer:
thanks MS----
yea, i like that $20 one already done. are there instructions to it as to where to solder the wires to?
http://jwweir.com
Old 01-16-2006
Faithful Departed
Originally Posted by jwgeetar
thanks MS----
I haven't used that exact model, but usually the points are labeled right on the PCB with "In", "T" for tweeter, "W" for woofer, or "Hi" and "Low", etc.
Old 01-16-2006
jwgeetar's Avatar
Dedicated Member
ok, went to the electronics store and found this one: http://www.jwweir.com/crossover1.jpg
we talked it over there and the tech guy wasen't sure if it was for me or not.... can anybody tell me if this one will work? the specs are on the "box end" in the picture.
i'll have to think about the wiring/soldering order if it'll work.....
http://jwweir.com
Old 01-16-2006
Faithful Departed
That wattage rating looks lean. Unfortunately I can't see the voltage ratings on the caps, so I can't say for sure.
PA vs Powered Mixer: Differences? SKYflyer Newbies 5 08-07-2005 12:34
hooking up powered Jbls to a powered mixer? Wireneck Other Equipment and Reviews 5 06-25-2003 11:20
Live Mixing Problems... MiXit-G Mixing / Mastering 11 04-07-2003 05:17
