XLR vs.1/4"?
How great is the difference when recording using the XLR jacks instead of the standard 1/4" on everything...I"m a wondering because is it worth spending the extra money on the podxt pro(rack) vs. the podxt live(floor pedal) just to get the XLR jacks?
And when connecting V-Drums to an amp that has XLR jacks...The drum brain is connected to the amp with a 1/4" jack, and the amp to the studio directly with an XLR...does it make it pointless to use the XLR after because there is a 1/4" connection first?--------(V-Drums-1/4" to amp-XLR to studio board in that order if I'm confusing you) On a microphone also. Please reply if you've upgraged to XLR's from 1/4" and let me know you're thoughts and results! Thanks alot! Dumby |
Since no one else is biiting, here goes:
An XLR cable is electronically the same as a quarter inch cable so long as the quarter inch cable is balanced-- i.e. a TRS cable ("Tip, Ring, Sleeve"). If the equipment you're using doesn't require balanced connections then you can use an unbalanced quarter-inch cable (i.e. a TS or "Tip, Sleeve" cab;e), or an RCA cable. Cables such as these should work just fine so long as your lines (i.e. cable runs) aren't VERY long. |
| XLR vs. balanced 1/4" inputs? | osz | Newbies | 5 | 10-10-2005 15:01 |
| ProCo Switch Witch/Hosa XLR Patch Bay | heartsoffire | Free Ads for Music / Recording Equipment | 1 | 12-29-2004 16:37 |
| Mic Cable: XLR or TRS ...? | A1MixMan | Microphones | 5 | 01-05-2002 15:03 |
| XLR vs 1/4" | mintwax | Microphones | 1 | 08-27-2001 10:33 |
| LowZ, HiZ, XLR, 1/4"... | SN | Recording Techniques | 0 | 10-07-1999 11:21 |
