Old 01-15-2006
sixways sixways is offline
Force of Nature
sixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond repute
getting the most out of loops
Hey guys,
I have been eq'ing, tweaking, effecting, and losing a battle to get my drum loops up to par. My current situation is: I don't have a real drummer (not that I have enough in's to record one if I did) so I purchased 2 drum loop CD's from http://www.betamonkeymusic.com. His drum loops are recorded bone dry so you can tweak them how you want (or so the website says). I'm basically wanting to know, am I wasting my time trying to get these sounding "pro"? I'm going for a regular rock drum sound (think Counting Crows, Pearl Jam, Dave Matthews Band). I'm using protools M-powered.
I've done some eq'ing, as recommeded by several books I've read on what frequencies to bring up or cut on individual drums, although it is obviously affecting all the drums in this case. Am I wasting my time?
Does anyone have any suggestions? Should I look toward midi drums (sampletank and etc)?
Thanks,
6
Old 01-15-2006
Force of Nature
anyone..anyone..??
Bueller? Bueller?
Old 01-15-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I haven't heard these specific samples, but you should be able to get some good sounds with a bit of tweaking. Eq, compression, reverb.....might try all these things, depending on how dry they are. It will take a bit of experimenting on your part, but these samples should sound better than most machines. I use samples some times, and DFHS more recently. Just takes some work to tweak them for your own use. Do you have a sample of just some drums, to post?
I won the internets......
Old 01-16-2006
Force of Nature
Do you mean just straight from the Cd-Rom?
6
Old 01-16-2006
Creamyapples1's Avatar
Creamyapples1 Creamyapples1 is offline
www.murphycabs.com
Creamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond repute
I use Betamonkey loops too, and they sound pretty decent imo
www.soundclick.com/murf
Kevin - www.icanquitsmoking.org
The Small Business Workshop
My Generic Crap
The Murphy Cabinet Company
Custom Hardwood Amplifier & Speaker Cabinets
Old 01-16-2006
Dags's Avatar
Dags Dags is offline
Dedicated Member
Dags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond reputeDags has a reputation beyond repute
Yo, sixways.
Something you could try is to make a copy of the loop you're using and cut and place elements of the loop around the place to add extra fills or grooves.
Extra kick here, additional snare there.
If you completely cut the loop up into its individual components, you can create a totally new groove and/or put each element onto its own audio track then treat the percussive elements differently, as if they were recorded onto separate channels.
I also have been known to cut out snares and pasting them onto other audio tracks (removing them from the original loop) that have been slightly detuned to give a more 'randomness' to the loop.
Have fun experimenting!
Dags
I have suffered for my music, now its your turn.
Loops pkay in Acid...not Sonar rjt Cakewalk / Sonar Forum 7 02-27-2003 17:14
fruity loops as a vst wrapper postalblue Cakewalk / Sonar Forum 2 01-30-2003 08:07
Making 'real' drums in Fruity Loops. Meshuggah Recording Techniques 11 11-11-2002 13:01
Cheapest Loops Around FZfile Sony Tools / Sonic Foundry 3 06-25-2002 20:24
Triggering loops live? shackx2 Sony Tools / Sonic Foundry 1 09-22-2001 03:21
