Old 01-14-2006
Modern_Talking Modern_Talking is offline
Junior Member
Modern_Talking is on a distinguished road
how to keep your studio nice & clean from wires
Hello to all . . .
How are you guys keeping your studio nice and clean from wires hanging, twisting up, tangles etc . . . By wires it could be anything, ranging from speaker wires, patch cables, insert cables, power cables etc etc . . .
I'm thinking of getting rid of all the single cable's and getting some snakes to connect all my sound modules, effect racks, patch bays etc etc . .
behind the desk or table there are lots of wires hanging behind and it totally looks messy there and with power cable there too, I guess I'm hearing hum noise being introduced into the mixing board. . . . .
I though of either buying snakes or just couple up all my wires (like effect unit patch cables, sound modules cables etc etc ) and tape them up and create a snake (of course not 1 large snake but few short snakes) as this way less wires would be showing at the back and things won't get tangle up that much and things will look at lot neater. . . . Plus power cords won't be touching the patch cables and chances are less or no interference will occur.
thanks
Old 01-15-2006
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
This took me a while to figure out: my studio features unbalanced cables, balanced cables, TDIF cables, MIDI cables, USB cables, the video cable for my monitor, speaker cables, AES/EBU cables, and of course there's an AC cord for every piece of gear in the room, which includes two mixers, two headphone amps, a pair of powered monitors, a pair of unpowered speakers and their amp, a mic preamp, a TDIF-ADAT converter box, a wordclock distribution amp, and Minnie Moore. Not to mention a Mackie Control and a computer with a monitor, keyboard and mouse. That's not even including the mic cables and whatnot when I'm actually recording!
I use a lot of twist ties and velcro strips.
With rack-mounted gear, I shorten the AC cord so it reaches the outlet with a little slack (all my racks have rackmount power strips in them). If trimming is not an option (I prefer not to cut on AC/DC transformer wires [wall warts]), I use twist ties to gather up all the slack in the wires. The power leads for the power strips plug into UPS boxes (two of them, and another for the computer). Probably the UPS is not necessary, but it reduces the number of cords plugged into the wall, and allows for neater routing.
Speaker cables generally are paired into split tubing so they don't wander all over the floor. This also makes it easier to cross the AC lines at right angles.
My mixers rackmount, and have the outputs on the face, so I use right-angle TRS plugs, then route the cables down the sides of the rack using harness clamps (like you would use to tie a wiring harness to a car frame).
One headphone amp is across the room from my mixers, so I routed the balanced cables from the mixer to the amp overhead, along an exposed wooden beam. The other one is mounted on the wall to the left of the mixer, and the cables are routed along the wall to it.
I also spend a bit of time figuring out how to best route all the cables...my computer is behind a wall, to keep noise down, so I have to deal with all the wires and cables for that too. Since I use fiberoptics between the mixer and the computer, I don't have to worry about interference there, but everything else is dressed away from anything that might cause noise or RFI.
"Digo: 'paciencia, y barajar.'" -- Don Quijote de la Mancha, Part II, Chapter 23
Old 01-15-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Tape gets messy after a while, the glue gets gummy and sticks to the cable. If you ever want to un-bundle the cables they will be covered by glue goop and you'll have to clean the cables. I use plastic ties (not twist ties) to bundle cables together. You can get them at a well stocked hardware or computer store like Fry's.
Velcro is also your friend.
http://www.misterpotts.com
Old 01-15-2006
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
Originally Posted by Modern_Talking
Hello to all . . .
nuff said.......
Old 01-15-2006
res0nance res0nance is offline
Newbie
res0nance is on a distinguished road
I picked up a couple of snakes to run between my mixer and patchbay, and to hook up the k2500 which has a bunch of outputs. They saved me a lot of messy wiring. For everything else, I use velcro straps to tie up cables, and I mounted various tie points onto my rack cases / stands / desk / etc to route the cables and keep audio separate from power. Got a few large hooks from the hardware store for the wall to put extra cables on so they are out of the way and not tangled up in a box.
Old 01-16-2006
Dogbreath's Avatar
Dogbreath Dogbreath is offline
Seeking help...
Dogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond reputeDogbreath has a reputation beyond repute
I'm a slob.
Old 01-16-2006
thane1200's Avatar
thane1200 thane1200 is offline
Medicated Member
thane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond reputethane1200 has a reputation beyond repute
Another vote for Velcro straps!
.........and make sure to keep signal wires away from power wires.
"See ya on the flip-side"
Old 01-16-2006
Fieva's Avatar
Fieva Fieva is offline
myspace.com/fieva
Fieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond reputeFieva has a reputation beyond repute
Another vote for slob, but I'd consider plastic ties and velcro
Heavyhitta Beats
Hustle Magic
Old 01-16-2006
jake-owa's Avatar
jake-owa jake-owa is offline
Banned
jake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud ofjake-owa has much to be proud of
Zip ties and screws under the desk. They make zip ties with a screw hole on the end, these work great.
Old 01-16-2006
Fishmed's Avatar
Fishmed Fishmed is offline
Why 2K?
Fishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond reputeFishmed has a reputation beyond repute
1) Place Related equipment as close to each other to reduce cable length
2) Use Snakes where posible
3) Route Power Cords away from Audio Cables
4) Zip Tie Audio Cables
5) Zip Tie Power Cords
Old 01-16-2006
Newbie
Zip ties are best if you know you won't be changing your setup often. If you tend to rearrange or rewire all the time (gear slut!) go with velcro, or a combination as appropriate... Also don't cinch your zip ties super-tight on wires, it can damage them.
  #12
Old 01-16-2006
easychair easychair is offline
Force of Nature
easychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond repute
Someone now makes reusable zip ties. I found them at Home Depot.
Happy Holidays
  #13
Old 01-16-2006
Junior Member
cable ties
I guess lot's of people are using velcro and those plastic ties. . .
Well, I went and got some heat shrink tubing and have made a few snakes out of those single 1/4" cables that I had been hooking up to the mixing board and patch bays etc etc . . . .
By combining the appropriate cables I needed to make snakes for my all my stuff that were on the racks and desk, now they are pretty much all snaked up. . . NOw I guess I will use velcro to tie up all those power cords and when i need change setup's it can always be opened up and used again . . .
  #14
Old 01-16-2006
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Someone asked about releasable cable ties?
http://www.partsexpress.com/webpage....ectGroup_ID=75
She's not the boss of me
  #15
Old 01-16-2006
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
Zip Ties and Velcro Ties
The velcro ties I use say on the bag "Hook & Loop Wire Ties", that might help your search on google.
Review – Studio Projects VTB1 mic pre Dot The Rack 68 07-21-2007 21:29
The business of running a small studio? ElSilva Studio Building & Display 47 05-04-2006 06:51
For those who have gone from Demo Studio to Big Production Studio. McButtsky Recording Techniques 18 10-14-2003 08:49
Nice Analog Studio Project Audio_Drivel The Rack 0 11-22-2001 14:28
Let`s build a SUN studio! Ola Lagarhus Other Equipment and Reviews 0 10-05-2001 12:59
