Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 01-14-2006
TytusHale TytusHale is offline
Newbie
TytusHale is on a distinguished road
Question Vs-1880 Db-25 Scsi ?
I just got this Recorder. can I use The DB-25 SCSI to send (data/ tracks) from the 1880 to my PC. to edit and then send it back to the 1880
Old 01-15-2006
Newbie
SCSI connector on the VS-1880
Answer: The SCSI connector on the VS-1880 is only used to connect a Roland CD Recorder, such as the VS-CDRII or the VS-CDR3. It is not possible to connect the VS directly to a computer via the SCSI connector. The CD burner is required if you want to back-up your recordings, or if you want to burn audio mixes of your songs to CDR directly from the VS-1880.
For information about transferring tracks from the VS-1880 to a computer, read here:
Roland Track Talk
Laura Tyson
Roland Track Talk
Does this fix your SCSI transfer errors?? D or V series... chrisbc Fostex Forum 5 04-13-2006 20:06
transfers VF160 --> pc wizzzard Fostex Forum 4 07-13-2004 09:20
Serious Problem w/SYNC: Using Both a 1680 and 1880 with Mixing Control on CuBase rcs Roland, Boss, VS Series Forum 0 08-28-2001 11:18
Compu-mix in Cubase, Using a VS-1680 and 1880, and Problems with Sync rcs Cubase User Forum 0 08-20-2001 12:22
FD-4 to scsi Zip disk to computer to CD-RW? jgibsosman Fostex Forum 4 06-24-2000 01:26
