Old 01-12-2006
dserious111 dserious111 is offline
Newbie
dserious111 is on a distinguished road
newbie with behringer question
Hey folks! I'm a newbie as far as mixers are concerned. I have a behringer 1204 fx pro mixer connected to my mbox. I have 2 mics connected to the mixer. The question is, is there a way that I can record each mic seperatly to its own track in a protools session? This would be really helpful, because when I record 2 people at the same time, their vocals end up on one track in protools. I need each person to have their own track. Hope I explained this clearly. Thx.
Old 01-12-2006
Thunder33's Avatar
Thunder33 Thunder33 is offline
Asst.Trailer Park Manager
Thunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond reputeThunder33 has a reputation beyond repute
what soundcard are you using? basically you can pan one mic left and one right and then send each output from the mixer into a separate channel.
Old 01-12-2006
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
You ARE panning the vocals to far left and right on the mixer right?
After you are assured of that, then you have to make sure that each of the tracks in ProTools is getting it's input from the proper input on the soundcard. I don't know how you do that in ProTools, but I don't think it is that hard to figure out.
All should be well then.
Old 01-12-2006
Newbie
Okay how do you send each output to a seperate channel? I have an imac g5 which is running protools le 6.9 through an mbox. The mbox is connected to my monitors and my mixer. My mixer (behringer 1204fx pro) has 2 mics connected. No , I did not know to pan the mics left to right. So you are saying the panning won't be a problem?
Old 01-12-2006
Thunder33's Avatar
if just run the left output to channel one on the M-box and the right output to channel two.
Old 01-12-2006
Newbie
Okay great! I got it! Thx a lot guys!
Old 01-12-2006
Creamyapples1's Avatar
Creamyapples1 Creamyapples1 is offline
www.murphycabs.com
Creamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond repute
You could use the aux 1 and aux 2 sends to route the signals to the soundcard if you wanted to use the main bus of the mixer to monitor the rest of the mix through.
Example:
Channel 1 - Aux 1 turned up / Aux 2 turned all the way down - Aux 1 output going to channel one on the sound-interface.
Channel 2 - Aux 1 turned all the way down / Aux 2 turned up - Aux 2 output going to channel two on the sound-interface.
Channel 3 - <insert instrument here> output 1 from sound-interface - with both aux 1 & 2 all the way down for that channel, and repeat for each subsequent channel.
You could hear it all on the main bus and still isolate channels 1 and 2 for recording purposes. Though running straight out of the Mbox to monitors pretty much yields the same results, I'm sure.
I use a similar setup, but I use my board to route the input signals and monitor playback at the same time, so I don't have to tinker on multiple devices.
Kevin - www.icanquitsmoking.org
The Small Business Workshop
My Generic Crap
The Murphy Cabinet Company
Custom Hardwood Amplifier & Speaker Cabinets
Behringer ADA8000 and Mixer question blarg Newbies 5 05-14-2005 19:03
New Guy question - Tascam 424MKII and Behringer 1202 related Jeff Hitman Recording Techniques 4 02-09-2005 12:50
Another newbie question... Phobea Digital Recording & Computers 17 12-27-2004 16:02
Newbie gear question. BenW Newbies 7 12-17-2004 08:46
Another newbie question... I know you guys get tired of them henry_mullis Keyboards and Sound Modules 2 03-21-2003 15:51
