Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-09-2006
cmyhre cmyhre is offline
Newbie
cmyhre is on a distinguished road
recording drums for use with drumagog
Ok so instead of going back and fixing a bad recording using drumagog I know I'm going in this time with sub-par equipment and room. I was considering close micing each drum individually and skipping the overheads all together. Having each cymbal on a seperate track would mean less work for me, should I just throw a dynamic mic (57, 58, 609 etc) on the snare, hat, kick, each tom and each cymbal? I'll be using drumagog to get the mic'ed sounds into midi and then dkfh custom and vintage for the sampling/ programming after that. Is this a solid plan to get the most out of a bad room, kit?
Old 01-10-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If you are going to trigger the cymbals using drumagog, yes. If you are trying to keep the real cymbals in the mix, no. Cymbals don't like to be close mic'd. If you are trying to keep the real cymbals, just use overheads. In the mix, use a high pass(low cut) filter to take everything under 600 hz out. That will get rid of the nasty room and most of the drums, leaving you with the shimmery part of the cymbal sound left for the mix. 600hz is a starting point, you can slide it up or down depending on what the problems are. This will work fine.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 01-10-2006
Newbie
The drummer, despite being a very good drummer has the wors cymbals I've ever seen so I think I'm going to be sampling everything. Thanks for the highpass filter tip, if I had a dencent set of cymals to work with that would be the way to go.
Old 01-10-2006
Farview's Avatar
You are going to have a very hard time trying to get the cymbal mics to trigger. You will probably have to do a lot of editing to make this work.
BTW most of the yucky sound in a cymbal is in the low end, the high pass might fix that as well. (as long as the cymbals aren't broken) I've done this with ZBT hi hats with success.
Jay Walsh
Recording drums?? Which option should I use for a room? trandg Recording Techniques 5 12-21-2005 15:46
DP-01 Users, recording drums, and after it's on the computer JazzMasterWil TASCAM User Forum 3 12-03-2005 22:47
If I am going to be recording live drums.. lyricist Recording Techniques 7 11-30-2005 19:32
Recording Drums In A Closet? ripingitar Drums and Percussion 8 08-17-2005 02:52
Recording the drums, for sampling reasons 11miles Recording Techniques 0 07-29-2005 05:59
