Old 11-04-2000
pisces7378's Avatar
pisces7378 pisces7378 is offline
www.kilroymusic.com
pisces7378 is on a distinguished road
Question
I thought that a DAT was a multi trak recorder. I had a Tascam Analogue "home studio" and it gave so much background noise and was so complicated that after it was all said and done it would have been easier to use a simple home stereo box "boom box" if you will and record the band live. I was thinking of using the drum machine to produce a first layer beat. And record it directly (digitally) into the DAT with zero background noise. Then on another track, overlay a guitar, or keyboard, or whatever, then keep overlaying bass sounds on other tracks, and maybe use the same drum machine to add accent percussion sounds...here is where a sampler would be PERFECT. Then come back and on another track lay down the vocals. And any other effects also on other tracks. Then here comes another problem??? How in the hell can I record vocals. With my Tascam I used the PA head. I plugged the Mic intot he head and then ran the head through the speaker cables directly into the 4 track. Well the Wattage of the PA head after 2 days fried my 4 track. Feeling like and idiot. I just gave up for a while. THen finally I rented a head for a PA with no power amp in it. That worked perfectly. However I can't afford to buy a head for a PA and I can't rent one every tiem I want to record something? What does someone like me do?... BUT Thank you from the bottom of my heart for even resonding. I was sure that NO ONE would take me seriously and would make more fun of me than help me.
Mike
Old 11-06-2000
regebro's Avatar
regebro regebro is offline
Insane Genious!
regebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond repute
DAT is stereo. ADAT is multi-track.
To be honest, you will most likely mot find anything that is much less complicated to record with than that Tascam. Recording with multi-tracks is kinda complex. With a double-speed portastudio and high-quality chrome tape the background noise should be tolerable.
How do you record vocals? You plug a dynamic microphone into the microphone input of your multi-track.
Old 11-06-2000
mojovoodoo mojovoodoo is offline
Senior Member
mojovoodoo is on a distinguished road
Wink
YEA regebro's right,esp.with a portastudio cassette you just plug straight into the four track,with tascam,they got an fx loop ,so you can add all the reverb and effects sound you want.but as far as the p.a. head thing,if it's a pre-amp you need(which in this case i don't believe you do)there is a company called ART, they make a reasonable tube microphone pre amp for $99(cheeeeeeaap!!)and until you upgrade,that does the trick,even when you do upgrade ,to digital,or a bigger machine ,or whatever,the ART tube pre amp seems to do alot of people pretty well.but try recording the vocal without the p.a. head and ,though it will sound dry,it still will record the voice
