Old 01-06-2006
Nalencer Nalencer is offline
Junior Member
Nalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond reputeNalencer has a reputation beyond repute
Acoustic Guitar Problems
I tried to record my acoustic/electric guitar by plugging it straight into the board, and all I got was a low rumbly sound. You could distinguish the chords, but it sounded awful.
When I try to use mics, I get the thing where it sorta "overloads" and the sound phases in and out between regular level and quiter. I probably has something to do with the vibrations, I guess. I tried putting the foam around the mic, but it still does this. The mics are a Behringer B-1 and Behringer XM18000s.
Old 01-07-2006
soundchaser59's Avatar
soundchaser59 soundchaser59 is offline
Reluctant Commander
soundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond reputesoundchaser59 has a reputation beyond repute
Does your guitar have a battery in it? If so, it sounds like a dead battery to me.
Mic choice and position/placement has everything to do with recording acoustic.
Just think how good you could play if you were sober!
My Little Corner Of The World
SC's MySpace
Old 01-07-2006
Junior Member
No, no battery. How would you suggest placing the mics?
Old 01-07-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Do a search, there are tons of great tips.
I like a set of SDC's in an XY at the twelth fret, and a LDC a few feet back to capture the ambient sounds......
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 01-07-2006
Junior Member
I ran a search and found a good method.
By the way, I'm glad to see that quote in your sig. At least someone's awake
Old 01-07-2006
grn's Avatar
grn grn is offline
www.michaelchagnon.com
grn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond repute
I like to use my Studio Project B1 or one of my Oktava MK012s and just stick it a foot back and aim it at the twelfth fret... I rarely mic in stereo unless it's like ONLY acoustic... but if there are other instruments, it's whatever... whatever sounds good.
Michael Chagnon
Twitter
MySpace
Old 01-07-2006
Junior Member
I was incorrect. The new setup does not work. The mikes keep phasing in and out and generally sounding horrible. What could be the problem?
Old 01-07-2006
Junior Member
Didn't see your post, grn. Just tried the single B1 at the 12th fret, works great. Thanks.
Old 01-07-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
GRN was right, I was assuming it was a solo acoustic piece for some reason.
If you were having phase issues with an XY your doing something wrong. Not sure what, but something......
Old 01-07-2006
Junior Member
I wasn't using an XY.
Old 01-07-2006
Acoustic_Daddy's Avatar
Acoustic_Daddy Acoustic_Daddy is offline
Junior Member
Acoustic_Daddy is on a distinguished road
Acoustic guitars should be mic'd at the 12th fret.
The reason you are only getting a low rumbly sound, is because the preamp inside the guitar itself is not powerful enough to send a decent signal. What are the pre-amps like in the board itself? If you are pumping the gains full ball, and the sound is still weak, you need another pre-amp inbetween the guitar and board.
I myself, use a Behringer ultragain tube pre-amp. (http://www.zzounds.com/item--BEHMIC100)
I use it for vocals and acoustic guitar, just to get some warmth with multi layered tracks. I too had the problem of the soft rumbly sound, then ran the guitar through this tube preamp, and into the 2 track, and i had volume.
I don't usually like Behringer products, but this ultragain was the best money I ever spent on an external preamp.
Good luck
"Who's ya acoustic daddy?" I am
Problems When Micing Acoustic Guitar samich17 Recording Techniques 27 08-13-2005 09:33
Beyer Soundstar II on Acoustic Guitar hognogger Microphones 15 04-08-2005 18:33
Problems recording acoustic & vocals at the same time lo beam Microphones 15 11-04-2003 17:48
reasons for stereo micing acoustic guitar Phosphene Microphones 7 10-23-2003 12:43
The best way to make an acoustic guitar heard live... microphone, pickup, or what? pisces7378 Guitars and Basses 9 03-19-2003 20:07
