Behringer Eurorack 1222FX-Pro question:
I've got a Behringer Eurorack 1222FX-Pro and I couldn't be happier with it. However I have a noob question about a few of the features. I've played for years and I've tinkered with recording on my own for a bit though I wouldn't call myself anything but a Hobbyist at present.
I'm mainly a guitar/bass kinda guy, so 99.9% of the time I only require the use of two input channels at a time. To route my signal to my M-audio soundcard I use the mon and FX outs. Question 1: the board has inserts on each channel, according to the manual these are to add effects or what have you pre-fade. How would you hook this up? I don't fully understand this at all. Also, the slot is labelled Insert I/O, can this slot be routed out to the input on a recorder or am do I have a bad case of wishful thinking? This Insert feature confuses me to no end. For mixing down, I've got some questions regarding how I should hook this stuff up. Currently I'm just running the mainbuss outs through a few pieces and into a Pioneer component CDR, would using the loop produce better results (effect wise)? |
Matt
http://www.precisionspeedonline.net/matt/sig%20pic.bmp Sound Innovations (under construction...) Use your ears and try things and if something works for you use it. -Al Schmitt |
Just wanting to see what the full range of what the feature could do. I'm at a point where I need a patch bay I believe, so I can multi-function the outs for this and that as they won't be used at the same times anyway. Just wanting to optimize the gear I have to it's fullest extent before I start tacking more on to it. I appreciate your assistance very much.
As I understand your reply, you get a cleaner signal path if you add the effects pre-fade? Say I want to use a compressor on a channel I have a Shure SM57 plugged into. The 57 is micing a guitar amp. How would I go about plugging the compressor into the insert slot? My knowledge and use so far has been through the loop so I've been using 2 outputs and then two inputs back in, but the one input confuses me still in this aspect. EDIT - Ok, I just looked up the insert cable, 1 1/4 on one end and 2 1/4 on the other, I assume the 1 connect to the insert slot then the 1 of the 2 to the input and the other to the output of whatever I'm using. The one 1/4 in the insert slot acts as the input AND output. Correct?
Kevin - www.icanquitsmoking.org The Small Business Workshop My Generic Crap The Murphy Cabinet Company Custom Hardwood Amplifier & Speaker Cabinets |
| Building a "Behringer homestudio" | Mr. Ins@ne | The Rack | 96 | 01-02-2008 19:06 |
| New Guy question - Tascam 424MKII and Behringer 1202 related | Jeff Hitman | Recording Techniques | 4 | 02-09-2005 12:50 |
| behringer 1204 pro question | drumboi | Recording Techniques | 1 | 08-01-2004 01:44 |
| Interesting Behringer Question | Magpie99 | The Rack | 8 | 08-27-2002 01:04 |
| Maybe the dumbest question yet??? | thehorseshoe | Newbies | 45 | 08-28-2001 23:38 |
