Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 01-04-2006
antispatula's Avatar
antispatula antispatula is offline
Force of Nature
antispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond reputeantispatula has a reputation beyond repute
simple mixer question
Hey, I'm new to recording. I've got a mixer, FINALLY. So I'm new to mixers. It's a peavey, and has 16 channels. I want to use an 8 track reel to reel. Someone told me my mixer won't work well for recording, because I have no islolated cue monitor. Can someone explain what this means? If I'm not mistaken, isn't that just used for overdubbing? The signal is sent to headphones, right? If so, what do I need to to this? I have "monitor" out, and each channel has a monitor level.....isn't this what I use? Thanks for helping out someone that doesn't know what they're talking about!
Old 01-05-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
The monitor level can go to a headphone mix - But unless each channel on the board has its own direct (tape) out, it isn't going to do you an awful lot of good for recording to the 8-track deck...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 01-05-2006
gullfo's Avatar
gullfo gullfo is offline
Dedicated Member
gullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond reputegullfo has a reputation beyond repute
if your mixer has "inserts" on each channel then you can use those to output to the recorder and the other 8 channels as inputs from the recorder.
an insert cable consists of a tip-ring-sleeve plug on the mixer side, and a pair of tip-sleeve plugs on the "effects" side. one is the output (send) and one is an input (return). you want your mixer send to go to the recorder input. use the channel trim to adjust level to the recorder as most inserts are "pre-fader" so you cannot use the channel volume to control the level. basically this will give you a clean signal to the recorder.
since you have 16 channels, you can use the other 8 channels as the "mix down" side... take the out of the recorder into these channels. with this set up you should invest in a patch bay so you can easily switch things around since during mixing you're likely to want more than 8 channels available for effects returns and so on.
Glenn
fossile music
Old 01-05-2006
Track Rat's Avatar
Total Gear Slut
What Peavey do you have? While they're far from ideal, I used one for a few years with an analog 8 track. As mentioned, as long as there are inserts on the individual channel strips, you'll be OK.
Mike
Old 01-05-2006
Force of Nature
ok I get it thanks!
Behringer ADA8000 and Mixer question blarg Newbies 5 05-14-2005 19:03
mixer question gtr_guy26 Other Equipment and Reviews 2 04-29-2005 13:31
Recording chain question Mixer to Delta 66 kybdplr Newbies 1 01-24-2004 18:22
How to record with a simple mixer delfdc Recording Techniques 6 09-18-2002 20:17
REALLY simple mixer question jdavis Newbies 5 06-30-2001 04:26
