Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 01-04-2006
djclueveli djclueveli is offline
Dedicated Member
djclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond repute
upfront vocals
i love this site because someone always has the correct answer . anyways can someone help me with this problem with the vocals? does anyone know how to make the lead vocals sound upfront everything else and still centered and wide without having to do more than 1 vocal take, using reverb, or using a chorus effect? I want the 1 take vocal to sound dry. upfront and wide. how would i do this? is there a stereo effect professionals use on the vocals to get them to sound upfront and wide while still dry sounding. I tried waves Stereo imager but that doesnt work to well with how i want the vocals to sound. i want to do this without having to do more than 1 take of my vocals or double tracking the vocals. anyone have any ideas on what i can do or any idea of where or what plugin i can use to get the vocal to sound upfront everything else. O yea what plugin is use to center the vocals too. thanks for the help guys!
Old 01-04-2006
Ford Van's Avatar
Ford Van Ford Van is offline
Banned
Ford Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond reputeFord Van has a reputation beyond repute
If you can score an Eventide H3000, there is a preset called "Dual Shift", and with a minmal of tweaking, it will do what you seek! I have yet to replicate this effect any other way where it sounds as great as the Eventide does it.
Basically, it is a pitchshift. Both left and right channels are delayed around 25ms. One side is pitch shifted up, the other down. How much you pitch shift and how delayed it is warp the effect in many directions. You pan the two channels all the way left and right.
Old 01-04-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Try sidechaining a compressor
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 01-04-2006
Dedicated Member
what do you mean by that
Old 01-04-2006
lomky lomky is offline
So much to learn
lomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond repute
Sidechain based on what? The rest of the instruments? I'm not trying to sound sarcastic, I'm just wondering? I've nerver gotten sidechaining to work properly.
Old 01-04-2006
greezyc's Avatar
greezyc greezyc is offline
Knows Not What He's Doing
greezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond reputegreezyc has a reputation beyond repute
I don't know about widening the vox, but if you want them to sound up front, don't add alot of reverb...
Instead, try some medium to heavy compression on the vocals with a slow attack, fast release setting and see if that puts them more up front.
Old 01-04-2006
nonfat's Avatar
nonfat nonfat is offline
Newbie
nonfat is a jewel in the roughnonfat is a jewel in the roughnonfat is a jewel in the roughnonfat is a jewel in the rough
I would suggest to look at mic placement and preamp gain levels first and foremost. If the source track is recorded with a "far back" sound, it would take some gymnastics to change that in the mix.
If you are happy with the source track, maybe use EQ to carve out a space for the vocals to sit.
Kick Me I'm Weak
Old 01-04-2006
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Yo CLUE:
If you have a dynamics feature in your rig, you can put your vocal up front with no problema.
When I mix tracks, I insert the vocal track into the dynamics/compression patch on my 2816 and then boost the stereo out until the vocal is where I want it.
You can also boost the stereo out when mixing; however, this pushes up all the recorded tracks. It works, if needed, when you have balanced the tracks to your liking.
Of course, you can run the vocal to a decent mic pre amp, then from there to an RNC and from there into the recording box or rig--then adjust when mixing. If you take some time when mixing, you should be able to get your vocal to where your ears like it before you burn the CD. It might take 20 minutes or 13 hours--oh, the joy of mixing.
Happy New Year
Green Hornet
Old 01-04-2006
Alexbt's Avatar
Alexbt Alexbt is offline
Force of Nature
Alexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond repute
I'd be very interested to know the mic used, mic placement, and what the room is like.
I've found that these 3 items are the most important parts of getting the vocal sound you want.
Recording Setup:
Power Mac G4 / M-Audio Delta 1010LT
1Ghz | 768MB RAM | Mac OS 10.4.5
160 GB Internal | 250 GB Ext. USB 2
Yamaha MG10/2 Mixing Console
Logic Express 7, Cubase SX & Deck 3
Keyboard Rig:
Kurzweil SP88 / Kurzweil PC2R w/O / Yamaha TX7
Old 01-04-2006
You run the orignal vocal along side the same vocal through a compressor
Old 01-04-2006
Dedicated Member
is the 2816 a plugin? if so where can i find it. is there any plugin i can download that can boost out the stereo or dynamics.
  #12
Old 01-05-2006
grn's Avatar
grn grn is offline
www.michaelchagnon.com
grn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond repute
http://www.recordinginstitute.com/R2KREQ/excomp.htm usually works
Michael Chagnon
Twitter
MySpace
  #13
Old 01-05-2006
Scottgman's Avatar
Scottgman Scottgman is offline
Legend in Own Mind
Scottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond reputeScottgman has a reputation beyond repute
Have you tried singing very close to the mic? Proximity effect can be the difference between a vocal sounding thin and "roomy" and sounding fat and "in your face." If you aren't doing it already, try getting really close to the mic (within a couple inches) while you sing.
Talk Nerdy To Me.
  #14
Old 01-05-2006
Yo Clue:
The 2816 is the Yamaha 2816 SIAB-DAW, whatever.
Studio in a box--digital audio workstation [not a PC program]
However, the 2816 fuctions in similar fashion to PC DAWs--it has a smaller screen, cursor movements and programs built-in: reverb, "dynamics" and EQ.
So, to answer your question, the 2816 is not a "plug-in." Sorry I didn't make that clear first time around.
You can also pan the music a little left/right and keep the vocal in the middle of the stereo field--this will, among several other things, put your vocal "up front." If you can listen to almost any Sinatra recording, you will hear the vocal up front.
Green Hornet
  #15
Old 01-05-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
I'd say put a stereo delay on the voice track. Leave the original track relatively dry (not too much reverb, and use a short reverb decay time), and then pan the delays hard left and right. The delays will give the vocals size, but won't wash them out. The lightly used reverb will give a little ambience which is probably necessary, but the key is not to overdo it.
http://www.misterpotts.com
  #16
Old 01-06-2006
mistarags2006 mistarags2006 is offline
Newbie
mistarags2006 is infamous around these partsmistarags2006 is infamous around these partsmistarags2006 is infamous around these partsmistarags2006 is infamous around these partsmistarags2006 is infamous around these partsmistarags2006 is infamous around these partsmistarags2006 is infamous around these parts
Pre Amp
Either an Avalon 737, or an Universal Audio La-610...does the trick everytime..makes mixing vocals ALOT easier...
  #17
Old 01-06-2006
Dedicated Member
whenever i change the pitch and pann them, i get a phase when i listen to it in mono. how much should i change the pitch by and how much should i pann so i wont get phase problems in mono
  #18
Old 01-06-2006
Man, I really wish you hadn't started two threads on exactly the same subject. It's a lot easier to deal with if it's all in one place.
I think you need to experiment. Set up your listening in mono and then play with various detunings until you get what you want.
I personally am not convinced that detuning is what you are looking for, but it is certainly worth a try.
Once again, I'd suggest you use delays on the voice. Leave the track in the center where you want it, and then pan the delays wide left and right. Again, you'll have to experiment with delay times and levels to get what you want. Ideally, the delays times will be locked to the tempo of the song.
  #19
Old 01-06-2006
ds21 ds21 is offline
Force of Nature
ds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond repute
I would like to know what sound your going for, ie: singer/band, song. I mean as you've seen there are many ways to go about it and each would probably sound better within a certain genre. But I'll add pre-delay into the mix (pardon the pun)
True Creation Comes Of Nothingness
-Winner Mix Contest 8-
-Winner Mix Contest 11-
  #20
Old 01-06-2006
Dedicated Member
the genre is hiphop
  #21
Old 01-06-2006
Force of Nature
the genre is hiphop
I would say What SonicA said with really short delays and some compression. but as was mentioned if the vocal sounds distant to begin with it's going to be hard.
where do you sit your vocals? jugalo180 DJ & Hip Hop Production 5 03-31-2006 12:31
Removing Vocals from CDs Knopfler Fan Newbies 7 11-08-2005 11:51
Vocals Distorting at High Volume? scarboro78 Mixing / Mastering 3 01-20-2005 15:52
Recording vocals tricks arsenaultk9 Microphones 26 12-30-2004 20:43
