Old 01-04-2006
ssman ssman is offline
Junior Member
ssman is on a distinguished road
presonus tubepre vu meter goes into red
I'm using an emu 0404 soundcard, and it says the input should be set so that the peak meter stays in the yellow region (to get maximum resolution due to digital). I have to turn the gain so high for this that the vu meter on my presonus tubepre goes into the red region. Is this bad, is there something I'm doing wrong. I don't really know what a vu meter is for.
Old 01-04-2006
Junior Member
also am I damaging my equipment when it goes into red? (mic/preamp/soundcard/headphone amp, headphone?)
Old 01-06-2006
Junior Member
please help, someone
Old 01-06-2006
treymonfauntre's Avatar
treymonfauntre treymonfauntre is offline
Magic Bag Of Sounds
treymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond reputetreymonfauntre has a reputation beyond repute
its fine if its in the red, as long as the clip light doesn't come on
http://www.floridadiy.com
Old 01-06-2006
jonnyc jonnyc is offline
2.5K Gold Member
jonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond repute
You really need to pay more attention to what your mic and converters are telling you, if they dont clip then you dont have a problem. Don't put too much faith into a meter on a hundred dollar box.
Old 01-06-2006
Junior Member
ok, thank you.
Old 01-06-2006
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
Does your sound card have a -10/0 /+4 adjustment. If your card has jumpers or adjustments to match the input device the meters should come up pretty close to each other.
I'm with the others in that it's ok that the level is pretty hot on the VU meter but if the clip light comes on...oh oh... not so much "damage" to the equipment but rather clipped/distorted audio. Also, constantly running those cheaper mic pre's up high could bring in amplifier noise. They pretty quiet in the mid range especially if you add a lot of the TOOB drive.
She's not the boss of me
Old 01-06-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
you're comparing Volume Unit (VU) and Peak Programme Meters (PPM). There is going to be a difference in readings. You're fine.
www.redlabaudio.com
Old 01-06-2006
punkin's Avatar
Yea...I understand that but as far as full meter deflections go, he should be getting good strong signal at the sound card if he's driving the input of the amp. I guess I should have prefaced my suggestions first with the question, how does the recorded signal look and sound? Is it peaking out or clipping or is it down in the dirt or best scanario...somewhere in the middle?
The amp has a pad switch...try using it you're constantly peaking the meter and the drive and/or gain controls arent' helping.
Old 01-06-2006
sorry, my post was directed toward ssman...i understood what you were talking about
www.redlabaudio.com
Presonus TubePRE Cageofmind The Rack 2 07-23-2005 15:21
FS: PreSonus TubePre - Perfect Condition Myriad_Rocker Free Ads for Music / Recording Equipment 6 07-13-2005 11:34
Presonus Tubepre soundjunky The Rack 4 02-14-2003 10:37
Buck62... did you ever get that Presonus Tubepre? cnote763 The Rack 6 12-22-2002 18:22
