an awful problem with acoustics
so after looking around for basic instructions/tips on (cheeply) improving room acoustics, i hardly found a site that was worth looking at. All i know is egg cartons can cheeply help with diffusion/absorbtion but im having trouble finding a large quanity. i even called local resturants, which didnt work like expected.
does anyone know any ways to help out my recording room (a de-shelved walk-in closet) im having a major problem with lower frequencys. maybe anyone here would know how to make a bass trap? thanks alot!
Harrison Weber Acoustic Music for the Independent Mind, Body, and Heart. Samples At PureVolume.com - - - - - - - Sweet free audio editer/multitrack recorder: "Reaper" |
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser. My tunes. Thanks! ![]() NB DA BEARS! |
AND!!!!
You might want to try the studio building forum here.
The fact that no one understands you doesn't mean you're an artist... |
sorry about that!
Hi, I'm new here, I understand that your having problems with
the conditions of your room recordings. Depending on what your instrument/s are and what recording source your using (tape recorder,computer,etc) Can make a differance. As far as lining an entire room with egg cartons and so on, I've heard of it before. Anyways, A little trick I have learned that might help is after recording, Using an equalizer on either seperate tracks or your entire recording can make a huge differance. If your problem is primarily "room noise" I would suggest placing your mic/s closer to your instruments to reduce the ambience your getting... Donno if I helped, But good luck. |
I adapted the Ethan Winer info to the stuff I just built for my basement. It imrpoved my mixing and sound dramatically.
Ethan has the info for you. Save you it will.......
Just think how good you could play if you were sober! My Little Corner Of The World SC's MySpace |
Awesome site apl. Once in a while HR.com provides me with something worth while. I just wasted a good 45 min scanning through that site, and I definately need another few hours to read it again and again to get much out of it.
Thank Ethan. He does an awesome job of bringing some very theoreotical concepts to earth.
OK.
Thank you, Ethan. There. |
#12
thanks guys.
i wasnt intending on putting them everywhere. but i think im going to do with some (about) 1 inch foam and either put them parallel to eachother on their corresponding walls or even mess with just one side and recording "aginst it" because my mic doesnt pick up whats behind it (for the most part:mxl v67g) thanks alot though! and that site is pretty sweet too
| Home studio advice? (acoustics) | semidiablan | Studio Building & Display | 11 | 10-18-2005 20:37 |
| LD Condenser Mic Problem | micr0s | Microphones | 5 | 01-09-2004 00:24 |
| Unwanted distortion in amp; possible preamp tube problem? | Whoopysnorp | Guitars and Basses | 11 | 09-16-2003 13:06 |
| Strange snap crackle pop problem | tlee2951 | Cakewalk / Sonar Forum | 12 | 08-08-2003 10:44 |
| SM58/AW4416 compatibility problem? | Amber Valetta | Microphones | 21 | 02-05-2002 15:39 |
