Old 01-03-2006
savageblues's Avatar
savageblues savageblues is offline
Senior Member
savageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud ofsavageblues has much to be proud of
Recording female quartet
Hi folks, I told my mother I would record her barbershop quartet. I plan on doing this at my Mom's house main floor which has a large L-shaped room filled with furniture, hardwood floors etc.
I am seeking some suggestion on what technique to use. I dont have any really nice mics, but I want to try using what I have.
What I was thinking was a Jecklin disk arrangement with my pair of ECM8000's. Also I thought I would try to position my V67 at the same location/distance from the quartet as a centre channel to mix in afterwards.
Any suggestions on distance, or another way of recording a quartet?
Thanks in advance.
"I wouldn't recommend sex, drugs or insanity for everyone, but they've always worked for me."
Hunter S. Thompson
Old 01-03-2006
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
yO bLUE:
Don't let Simba catch you in the tall grass.
Recording females in multiple numbers I have done in the past and I'm glad it is PAST. [Words of Yoda]
If the girls are amateurs, you should not have much of a problem no matter how you set up as they will only hear their voices and probably be happy.
However, dealing with professional multiples of girls, better have your Lion taming whip nearby. [Oh girls I'm just kidding, a "bit."]
If they are singing "without" music, it will be easier. If you are using recorded background stuff, put the music into your DAW and then each time there is a flub, just rewind and do it again.
Don't try and do more than three songs at one session--ear fatigue and need for a drink.
Mixing will be a job depending on your gear, use of mic pres, etc.
Happy New Year
Green Hornet
Old 01-03-2006
Senior Member
Thanks Hornet -
These old girls have been singing and competing in barbershop quartet and Sweet Adelines for years. They are used to singing without music during performance. I just hope to capture a good performance from them - one song at a time.
Any comments on mic's/technique/placement for this type of arrangement?
Hunter S. Thompson
Old 01-03-2006
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
I'd say place them in a '+' formation....with the microphones in the middle. A nice, ideal way would be to use two figure eight microphones. That way you'll have sound coming from each direction being picked up by the two mics. This would make life much simpler.
Otherwise, you could also just set them up in a line facing their individual microphones. I personally would go with individual microphones, depending on how they sound, because the sound of the quartet is based around the few, individual sounds and nuances. But at the same time a couple room mics wouldn't hurt either...because it IS a quartet and you want people to hear what they sound like as a whole (and usually groups that sing that type of music balance themselves pretty well). Then blend to taste.
www.redlabaudio.com
Old 01-03-2006
Senior Member
OK - But for some reason I figured it was better to let them create their whole barbershop sound (they practice at individual dynamics as part of their performance) rather than using individual mic's (and subsequent mixing - arrgghh!!)
I thought that maybe a strong L/R separation between singers wouldnt sound natural for barbershop. I thought that standing them in a line (or large radius semi-circle) pointing toward a stereo pair would capture a nice stereo image without an unnatural stereo effect. This is how they normally perform.
Hunter S. Thompson
Old 01-03-2006
you could do either way. really, if you (and they) feel like the emphasis is the sound of the entire group...then mic the entire group. But you'll also have less control over it afterwards which can hurt depending on your room, mics, etc. And if you record them individually, you don't necessarily have to pan them to get a strong L/R separation. It all depends on if you want to make it sound like a natural, live performance...or a nice, fancy, studio recorded CD. Listen to any famous quartet/quintets (ie. Boys II Men, etc.). Not exactly the same style, but a vocal group nonetheless.
A stereo pair would work fine too...again, all depends on what you're going for and how much control you want later.
www.redlabaudio.com
Old 01-03-2006
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
Watch them when they rehearse without any mics. Walk around and listen. Find the spot where all the vocals sound balanced; put an X/Y pair there.
Old 01-03-2006
Senior Member
Thanks Harvey. I will search for the spot. Is the ECM8000 suitable for an XY pair?
Hunter S. Thompson
Old 01-03-2006
Huh ???
Not really, they're omni so there's not a lot of directionality. They could be used as a Jecklin disk pair.
Can I get advice from those who have a home studio? Chrisku13 Studio Building & Display 56 08-21-2006 23:20
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
need female narrator for fifteen minute voice recording ken addison Newbies 0 01-07-2005 19:09
Recording female vocal trio Bloomington Recording Techniques 4 10-23-2001 09:39
