need some tips for recording bass and drum
hi guys. recently i just finished recording the guitar part of my song.
i really have no idea how to record bass and drum? should i plug the bass directly to my "m-box" or record the bass sound from the amp? and also, i have a drum machine and anoter very simple tama drum set. which one do u guys recommand to use for like home-studio recording? thank you ![]() |
If you have an amp with a direct out, you could plug a lead from the amp into the soundcard in order to record the bass with least fuss and maximum signal to noise ratio (just watch the recording levels though!) But I would hazard a guess and say that other more qualified people than I would recommend, if possible, to mic up the bass cabinet in order to record the bass sound as it is meant to be heard. Plugging a bass straight into the soundcard will generally result in a low-level muddy, twangy sound that will not be very useful in a song.....unless the M-Box has a preamp of sufficient gain in order to overcome this usual direct-in problem? The drum machine, given that the outputs should already be sending the sound out at line level, can be plugged directly into the soundcard - tweak the output so that the volume is below clip point on your DAW meters. Good luck! Dags
I have suffered for my music, now its your turn. |
And you might want to try a blend of the two. Run a DI and mic'd. I usually end up using more of the signal from the mic'd track with a touch of DI blended to taste.
Food for thought.... |
| Bass Drum Problems.. | RGProductions | Recording Techniques | 1 | 08-21-2005 05:27 |
| wat it takes for kick.. mic or treatment. | lbcstudios | Drums and Percussion | 11 | 02-27-2004 19:47 |
| Kick drum vs. Bass Guitar Round 1 | Scottgman | Mixing / Mastering | 11 | 01-29-2004 04:50 |
| Need Tips on Bass Drum Sound for Recording | Metal Marc | Drums and Percussion | 9 | 10-27-2003 13:55 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
