Go Back   Home Recording > User Forums by Brand > Roland, Boss, VS Series Forum
Reply    Audiofanzine Roland boss Roland boss News Roland boss Medias Roland boss Tests Roland boss Articles Roland boss User Reviews Roland boss Classifieds Ads
Old 01-02-2006
wpawley's Avatar
wpawley wpawley is offline
Newbie
wpawley is on a distinguished road
Question Snake usage
Who uses a Snake with your VS unit's during live recordings? Did you make it yourself or is it store-bought? I'm just trying to figure out if it would be cheaper for me to have one made/make it myself or go through one of the Music Stores to get one. How long is it (100' seems plenty long)? Does anyone make one specifically for the 2480?
Old 01-02-2006
Zeeb Zeeb is offline
Newbie
Zeeb will become famous soon enough
If you have to hook up to the channel inserts on the mixer, just plug the 1/4 plugs to the first click not to interrupt the signal. Don't use TRS plugs in that case. And maybe put the recorder next to the mixer instead of 100 feet away??? You won't have balanced cables, so 100 feet away is not a good idea, anyway. Also, if they do use effects in the mixer inserts, you can make adapters to tap off the ring. If it's a real nice pro mixer, it may have 25 pin D-Sub connectors for balanced direct channel outs for recording. 8 balanced outs per connector. The recorder only uses 1/4 or 1/4 TRS for input. The D-Subs on the Roland are for SCSI drives or a digital R-Bus connections. Then you'll need 25 pin D-Subs at the mixer to 1/4 TRS at the recorder. With balanced lines you can go 100 feet then.
Old 01-02-2006
easychair easychair is offline
Force of Nature
easychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond reputeeasychair has a reputation beyond repute
wpawley-
I'm sure lots of people use various snakes. A description of how exactly you use your VS unit will be useful in pointing you in the right direction.
Happy Holidays
Old 01-03-2006
wpawley's Avatar
Newbie
The 2480 is also a mixer and I was thinking of using the mixer capabilities along with the recording capabilites, sorta killing 2 birds with one stone. 100+ feet of mic line is a lot of line and I know most cases I can get away with a lot less and have a lot less lose. I was just wondering if anyone is doing the Snake trick and how it has worked out.
Old 01-13-2006
jarmugar's Avatar
jarmugar jarmugar is offline
Newbie
jarmugar is on a distinguished road
I am using a 16 channel mixer hooked onto my BR1600. I just made 8 short leads and plugged them into the inserts on the mixer to the line inputs on the Br1600. Works very well, good sound + you can fine tune input sound using the mixer faders. I have attached a picture, hope it's clear enough to see.
http://djjoel.kol.co.nz/pic8.gif
problem with snake interference pearldrum944 Recording Techniques 2 12-01-2005 10:00
Help with wiring custom snake???? owen_vallis Other Equipment and Reviews 6 02-21-2005 22:25
Amp and mixer question....What comes first in a live setup? sjaguar13 Other Equipment and Reviews 15 09-18-2003 03:07
Raw Snake Cable MMHaus Studio Building & Display 5 05-09-2001 16:38
