Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 12-31-2005
Change of POETS's Avatar
Change of POETS Change of POETS is offline
Boom Bap
Change of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond reputeChange of POETS has a reputation beyond repute
Eliminating frequencies... help!
Hello, oh wise ones
I'm having a bit of trouble on a mix of mine, and I believe it's being caused by sub-harmonic rumble. When analyzing the frequencies in the mixdown, I'm getting about -72db to -50db from 40hz down... even around 20hz, I'm well above -72db. I thinks it's adding too much to the mix, not allowing me to increase volume in the mastering...
So, I've tried EQing it out, but to no avail. I've used a 30 band EQ and cut everything below 40hz only to find that the volume levels in those frequencies change very little at all. Should I set up a chain of EQ's to cut below the 40hz line?
Is there a better way to eliminate the troublesome frequencies?
Any help is greatly appreciated.
Here is a link to an MP3 of the track in question, if you have any suggestions.
http://www.ysgrecords.com/barwars/ba...etakesback.mp3
Thank you.
-Brian
http://www.changehiphop.com/images/pics/Signature.jpg
Preview of the new Album here!!!
Mixing and Mastering services for your project, contact change@changehiphop.com
Old 12-31-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You need a high pass filter. Set it at around 70hz to 100hz. 40hz is too low, EQ doesn't work the way you think it does. It is more of a gradual dropoff, if you set it for 40hz, you are only going to be 6db down at 20hz. Using graphic EQs for this is kind of pointless.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 12-31-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Instead of attacking it by frequency, you can try it by volume with an expander.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Wave files, MP3s and frequencies rapedbyape Newbies 2 09-01-2004 02:57
where is my high frequencies? Only hollow low end sound! solanova Mixing / Mastering 1 09-29-2003 00:57
Using Parametric EQ to sweep frequencies TripleM Cakewalk / Sonar Forum 2 05-07-2002 13:46
Eq? sipi1910 Newbies 50 02-08-2002 01:55
EQ Frequencies Major Tom Guitars and Basses 8 01-01-2002 14:06
